this week's mods
this week's mods
so i don't need to take up a lot of room here explaining the mods, but i did the +2 rear sprocket from renthal (so much lighter than stock) wasn't too satisfied with it. i thought i was going to gain more torque than i actually did, so i have a -1 for the front on the way. Pair removal with block off plates, burnie morgan airbox mod, gsxr brake swap including MC and new EBC HH pads. holy ****. this thing stops sooo fast, incredible upgrade. right now i have bent the hell out of the original reservoir bracket to make it work, its ugly and sticks way out. this is just a temp fix, that and since the MC is a little bigger so my brake cables are having a tough time fitting in there well. this is due to the piece of the MC that sticks out and gets in the way of the banjo bolts fitting in comfortably. What recommendations do you all have as far as making my own reservoir bracket that isn't too complicated that i can do with minimal tools? AND What can i do about the piece of the MC that is in the way, can I cut it off?
Bracket = Piece of alu and some time with basic tools...
The part you are talking about, it's the tab for aligning the banjo's right? That you can most definetly cut off... It's just for making sure the banjo doesn't rotate to a bad angle when you torque it...
oh man those brakes are sexxxyyyy. ive seen info on them here but i wanna know first hand from you how hard are they to install? direct bolt on? and how much were they to buy? brake upgrade is in my future. i bet that thing will buck you over the bars if you tap the brakes too hard, haha
mine is off a 01 gsxr 1000, you can see from the pics of my hack-job reservoir mounting system, that lanz hit the issue right on. since i did the MC as well. straight up bolt on setup otherwise. took a little bit of moving stuff around. for instance i ended up using the MC-clipon clamp from my old (stock) setup cause it was smaller than the one from the gsxr and fit in with the electronics better. the difference is amazing. I tried it with the used pads that were on the 6-pots, eh...they were okay. so i got some shiny EBC HH and put those on. if you've read the other threads on this topic they say you only need one finger to brake. and seriously, you only need one finger to brake, its a great mod. oh yeah, $125 for the whole thing off ebay(calipers, lines, MC, reservoir, and used pads), and $75 for a full set of new pads. worth it.
