Swingarm is now braced
Old Mar 10, 2009 | 06:36 AM
I just got a call from the chap who I got to weld on the 900RR brace to my swngarm and the job is done (cost me $100 CDN). I`ll be picking it up on Friday, then it`s off to the powdercoater`s to get it done in semi-gloss black (along with the footrest brackets and rear caliper bracket). I ordered up some new bearings and seals for the arm too so it`ll be good as new (actually better) when it install it. I`ll be repacking the linkage bearings too while I`m at it. Can`t wait to have it on and put it through the wringer
Old Mar 10, 2009 | 06:44 AM
chickenstrip's Avatar
chickenstrip
Pics? It would be great to see what you are up to.
Old Mar 10, 2009 | 06:47 AM
They look awesome. Looks like they all should've come that way in the first place. Be sure to post up some more pics of that awesome bike when you get it all together.
Old Mar 10, 2009 | 10:05 AM
JamieDaugherty's Avatar
PICS!!!!
Old Mar 10, 2009 | 12:17 PM
FL02SupaHawk996's Avatar
Fastest Color
Just in time for Spring!
Old Mar 10, 2009 | 12:41 PM
Will post pics when it's all together. I am quite looking forward to it
P.S. Along with my snazzy new Jamie D machined shift lever and Heim-joints. Should make shifting a real joy too
Old Mar 11, 2009 | 07:37 PM
Just received my 1/6 turn HRC throttle tube today too. Looking forward to getting all these new goodies on
Old Mar 12, 2009 | 04:22 AM
One you get that installed and ride the bike you'll have to let me know what you think. A couple of years ago I installed an RC45 throttle tube which converted it to about 1/4 turn. It lasted two days because I hated it. Parking lots were a nightmare and I could barely make it up my 200' gravel driveway without kicking it totally sideways. It was actually pretty unsafe, 1/6 throttle sounds even worse. I've heard of others doing this and they liked it. Maybe it was just me!
Old Mar 12, 2009 | 05:40 AM
Will do Jamie
BTW, I am currently running the RC45 tube and like it. I tend to like quick action throttles (on bikes and snowmobiles anyhow) so I should like this too. If I don't however, it is a quick return to what I now have.
cheers
Old Mar 12, 2009 | 06:15 AM
cliby's Avatar
re: throttle tube. Will be good to hear your reaction. I agree with Jamie and had the same impression also after trying an RC HRC throttle. I think a better solution might be the ramped throttle tubes they sell for some dirt bikes - so the transitions and small throttle movements are actually slowed down (throttle:carb) for better control and then the ratio is increased at full throttle.
Old Mar 12, 2009 | 08:48 AM
I did my DIY version of that... Take a thin strip of plastic 2-3mm in thickness and file a groove in it for the throttle cable... stick it in there and test it... Just lift the cover part of the throttle...
The effect is like the ramped ones... Dunno what ratio mine is, but I got it to where I like it... nice and precise at small throttle opening and increasing att full throttle...
Old Mar 12, 2009 | 08:55 AM
yruyur's Avatar
I'm curious of the weight difference on the swingarm before and after. Looking forward to pics also.
Old Mar 13, 2009 | 03:25 PM
I haven't weighed the new braced unit (picked it up this morning) but he brace was quite light (aluminum after all). I cut all the unnecessary brackets off today and dropped off the arm, footrest brackets and rear caliper bracket off at the powdercoater's this PM. Can't wait to get it all back (in semi-gloss black).
cheers
Old Mar 13, 2009 | 07:57 PM
I made one awhile back. The 900rr brace is hollow aluminum and is very light.
Old Mar 13, 2009 | 10:43 PM
nath981's Avatar
can you notice much difference on the street with the braced swing arm?
Old Mar 13, 2009 | 11:09 PM
LOL I actually went on exactly one ride down the street with it to get pizza before I took the bike home, took it all apart and decided to replace it with a custom sp2 swingarm, and the bikes been apart ever since, thanks mostly to my obsession with never allowing this bike to be finished, several fabricators who kept ******* it up, and having no time between a few long stories and now going back to college and working.
Anyway you could get a better answer a few posts up from FL02SupaHawk996, it's now on his bike and unlike me he actually rides his instead of just staring at in the corner like I do If nothing else it looked awesome, and I think really complimented the rest of bike well. I like mods that only look like mods to someone familiar with the bike.
Old Mar 13, 2009 | 11:41 PM
nath981's Avatar
well captain, thanks for sharing that with me and for the apparently honest reply. I'll check with FLO. thanks, nathan
Old Mar 13, 2009 | 11:46 PM
nath981's Avatar
Is the difference noticible and positive with braced swingarm for street riding, especially in that the hawk was intended to flex somewhat?
thanks, nathan
Old Mar 25, 2009 | 06:34 AM
Just got a call from the powdercoater my parts (braced swingarm, footrest brackets, rear brake caliper bracket) are ready for pick-up.... woohoo!!!! can`t wait to see what they look like!
Old Mar 25, 2009 | 07:06 AM
Fastest Color
You gonna love the braced swingarm's added stability!
Old Mar 25, 2009 | 07:16 AM
I am really looking forward to it, that and the modified shock (being able to adjust both hi and low-speed compression damping will be a lovely thing). Time to get the old girl out fo hibernation soon!
Old Mar 26, 2009 | 03:55 PM
Just picked up and un-wrapped the parts. Everything looks pretty good although I will have to put the wire wheel to a few spots (nothing major). The finish is a bit glossier thtan I had hoped but, all in all, it looks pretty good. Can't wait to see everything mounted!
Old Mar 26, 2009 | 04:43 PM
Truckinduc's Avatar
PICS PICS PICS
Old Mar 26, 2009 | 04:44 PM
Truckinduc's Avatar
Im beginning to brace mine.
Old Mar 26, 2009 | 04:51 PM
zmaniv's Avatar
I cant wait to see what you do for a brace. Should be sweet
Old Mar 26, 2009 | 04:53 PM
Truckinduc's Avatar
tubular
Old Mar 26, 2009 | 05:38 PM
zmaniv's Avatar
Square tube or round?
Old Mar 26, 2009 | 08:15 PM
Truckinduc's Avatar
round. I dont wanna thread jack Mikstr's thread, So ill post pics in my build thread.
steve.g
Apr 14, 2009 06:08 PM
steve.g
Apr 1, 2009 07:50 AM
superhawk205
Dec 30, 2008 05:26 AM
2Phaast
Aug 18, 2006 02:06 AM
2Phaast
Dec 26, 2005 09:59 PM
