Stock front forks questions
Old May 24, 2010 | 03:39 PM
Grasshopper's Avatar
Grasshopper is on a distinguished road
What weight oil should I run? I'm thinking something heavy like 20 or 30.
What height should it be from the top of the fork tube? Is this with or without the spring installed? Fully compressed or fully extended? A volume number might be easier.
The forks are stock and I just want to freshen them up before I turn a few laps at Road America. I plan on doing a full race tech upgrade soon but not before I ride RA. I'm also planning on a shock upgrade.
I have my race Svs for primary track use but I can't help but turn a few laps on the superhawk.
Old May 24, 2010 | 04:34 PM
You should use 5wt oil in the forks. The fluid height is 130mm with the springs out & the forks compressed or 448+\- 2.5 cc's or 15.2 +\- 0.08 oz
Old May 24, 2010 | 05:40 PM
Wouldn't some thicker oil improve my damping a bit especially if I'm really riding hard? 5 weight oil seams so damn thin. I run 30 weight in the SVs stock forks.
Old May 24, 2010 | 06:14 PM
Actually the forks are a bit over damped in the stock form. In fact the band aid fix for removing the .56 kg\mm springs and replacing them with .90-.95 kg\mm spring is to use 7.5-10 wt so 30wt is way too much.
Doesn't the SV use damping rod forks? as opposed to the cartridges that the VTR uses. That would be the main reason for the differences in the wt oil used.
Old May 24, 2010 | 06:56 PM
Little_Horse's Avatar
2nd mouse gets the cheese
I use 7 to 7.5 weight. Actually the air gap can vary some, just make sure it isn't much different then suggested and that it is the same in both legs. I think I have a 140mm air gap.
Old May 24, 2010 | 07:07 PM
Alot of this info was discussed on this thread
https://www.superhawkforum.com/forum...ad.php?t=17943
Old May 24, 2010 | 07:44 PM
You are correct about the SV forks. I'll put some new oil in the superhawk forks and go from there. I'm learning this new bike and making sure everything is safe and right before I really start riding it hard. I'm kind of easing into it. As far as I know the fork oil is complete crap and has never been changed with 24k on the clock. The front end feels way too soft.
Old May 24, 2010 | 08:50 PM
You would be surprised how much of a difference fresh oil will make. If you are riding it hard you might rasie the oil leave to around 120mm to start and see if you bottom out (then raise the level a bit more) or if it feels like it is locking up at the end of the travel lower the level 10mm or so until it feels right.
NZSpokes
Jan 23, 2015 07:57 PM
VTRsupersport
Feb 29, 2012 05:09 AM
katryder1@gmail.com
Oct 30, 2010 04:09 PM
flyguyeddy
Apr 18, 2007 01:57 PM
OldHawkNewB
Mar 19, 2007 04:17 PM
