Staintune Jetting? Ohlins Shock install? ??
Old Jun 21, 2010 | 08:55 AM
mortbike's Avatar
mortbike is on a distinguished road
Hello -I will be installing the Staintune high pipes with optional silence baffle removed soon. I will be using the OEM air filter. The Staintune tech guy insists it will not need rejetting as long as I stay with the stock air filter even with the silence baffles removed. My bike is bone stock right now and runs great. I would like to avoid a complete jet kit install if not necessary. I am going to "de pair" it(not done yet). Do I need to add a shim under the needles(size?from radio shack?) or readjust fuel mixture screws? Any advice from members and other Staintune owners is appreciated and thanks to those who I have already returned my pm's.
I am in Florida at sea level-it is hot and humid!! I will also be installing an Ohlins rear shock-I have a factory service manual but any tips on the shock install would be appreciated? Lastly-my little 2005 owners manual says the oil filter should be torqued to 26NM while the factory service manual says 10NM? I think 26NM is a misprint? Thanks for any help-Mort
Old Jun 22, 2010 | 10:05 AM
I wouldn't torqe the oil filter at all. Make it hand tight, usually about 3/4 turn once the gasket seats.
Old Jun 22, 2010 | 10:26 AM
If you don't have it, here is the tech data and mounting instructions for the shock.
http://www.ohlins.se/Our-products/Mo.../Sport/HO-701/
Old Jun 22, 2010 | 01:06 PM
Stevebis1's Avatar
10 NM is about 7 ft-lbs. That sounds right for hand tight
102dals
Jun 16, 2007 09:09 PM
Randman
Apr 3, 2007 06:11 PM
captainchaos
Sep 20, 2006 05:37 PM
CNI Dawg
Jun 3, 2006 06:03 PM
superbling
May 20, 2006 03:36 PM
