New VTR owner Spring Question
Old Mar 24, 2007 | 03:51 PM
liquidspace's Avatar
liquidspace is on a distinguished road
Hey guys great forum and like most full of excellent info, however, I still have one simple question even after hours on the search.
What do I need to do to simply remove stock springs and replace with new RT .90 springs? No gold valves...just springs and oil. With my old SV I just needed to remove old springs and install new ones and adjust the spacers and oil./ VTR has the added complexity of dampening adjustment?
Can I do this job without removing the forks?
Thanks for any help or if you can point me to a post for spring replacement only ?
Old Mar 24, 2007 | 10:11 PM
It's pretty much the same. With the damping rod there's a little trick to getting the adjusters right. When you get your springs and oil lemme know and I'll walk you through it.....on second thought...
I knew I posted this before: https://www.superhawkforum.com/forum...ping#post34368
If you want to replace the oil then the forks have to come off the bike, period.
Old Mar 25, 2007 | 05:21 AM
Thanks Greg.....that's exactly what I needed! Got the springs and US-2 10wt oil in on Friday and should have it completed by lunch. I'll use a tube and brakeline bleeder to suck as much oil out as possible and next time I need to replace seals I'll remove forks and ALL oil......and maybe revalve at that time.
Thanks again!
nath981
May 3, 2010 09:30 AM
malahhaor
Sep 30, 2008 05:08 PM
synaptik
Apr 12, 2008 07:48 PM
filter_jam
Apr 12, 2007 02:18 PM
jneel
Mar 8, 2007 10:06 PM
