Latest OCMD project: modded airbox lid
Old Sep 21, 2014 | 10:23 AM
  #151
RoadManiac's Avatar
European Member
Can anybody with their snorkel or FIL mod make a onboard vid where i can hear those revs climb, i think mine is jetted good but i have no comparison
it doesnt stutter or fart in anyway.... no backfires either so its pretty good
my set up : stock main jets, 48 pilots, mixture screws 2,75 front, 3 turns rear, so its pretty lean already compared to others on here with snorkel or FIL mod but compared to mikstr its rich
Old Sep 21, 2014 | 10:33 AM
  #152
if it doesn`t surge at constant throttle (lean) or hiccup and load up when you gas it (rich), chances are you are close.
Old Sep 21, 2014 | 10:43 AM
  #153
Originally Posted by NZSpokes
At least that will help tell me if it wants more fuel. Just have to make up my mind on sizes. Will probably copy Crux main size. I have smaller idles which I can drill.
Don't copy mine exactly. Start a little smaller, like lower 190 range mains and go from there. I would hate for you to drill yours out to 198F & 200R, only to find it's too rich.
You aren't ordering jets? You're actually drilling them with a drill bit?
What have you done, the F.I.L. mod or opened up the snorkel?
Old Sep 21, 2014 | 11:32 AM
  #154
NZSpokes's Avatar
I was going to drill but drill spare jets. I want to keep the stock ones so I can go back to a base setting if needed. So im ordering 185,190,195,200. That will get me ball park then fine tune from there.
My spare jets have a different thread pitch.
Old Sep 21, 2014 | 11:36 AM
  #155
NZSpokes's Avatar
Dont base your tune on other bikes. Altitude, motor etc dictate that.
Mikstr is lean probably due to motor mods and HRC needles. Your setup is pretty much what I had with the snorkel mod. Mine will be different to Crux as im on different needles.
Old Sep 21, 2014 | 12:27 PM
  #156
don't be spreadin' rumours... my engine's stock
lol
Old Sep 21, 2014 | 01:11 PM
  #157
NZSpokes's Avatar
Just rode it after lifting the needles. Oh my god. What a noise. Power is immediate. Couldn't do a power run as it is gusting 120kph here. I overtook a car and she was trying to lift the front. Best it has ever run down low and mid.
I giggled like a girl.
Jets wont show until at least Wednesday.
Old Sep 21, 2014 | 04:42 PM
  #158
Isn't that an awesome feeling?
Makes the bike completely different but so much better. If others knew what the difference was that this modification made, those that have the ability to do this modification, would be doing it right now.
Old Sep 21, 2014 | 06:35 PM
  #159
What about this weekend? I even have an old K&N somewhere...
Old Sep 21, 2014 | 07:46 PM
  #160
Do it! I promise, you will not regret it.
Micky, Spokes and I have had fantastic results. Three for three.
Old Sep 21, 2014 | 11:57 PM
  #161
NZSpokes's Avatar
Well Im not there yet. But on the way to work I found it was lean on idles so went another half turn and it got better. I had a appointment on the way home and gave it another half turn. Better again but now over 3 turns out. Need bigger idles.
Mid range is stunning. Top end is flat and surging. But on stock mains. Picking up jets tomorrow.
Coming up the driveway the front wheel came up. Thats not happened before.
I cant wait for new mains....
Old Sep 22, 2014 | 04:26 AM
  #162
RoadManiac's Avatar
European Member
Same here i have lifted the needles up by 2mm runs so nice compared to stock,
also what do you mean by surging ? i am dutch so some terms i still dont know what the bike is doing when its surging ???,
for reference when i am at like 4000 rpm cruise in 6th on a freeway doing like 65 mph it pulls away nicely to 200 kph not really fast but not stuttering or anything.... air over here is getting colder & denser with moisture and it seems the hawk cant get enough of it it goes like stink !!
@ NZspokes i have just done the snorkel mod but lifted the tank about 1.3 cm
as above lifted needles bij 2mm can i go more ? basic knowledge is that the higher the needles..... fuel+air is entered faster into the carb
Old Sep 22, 2014 | 11:19 AM
  #163
NZSpokes's Avatar
Lifting the needles allows more fuel at any given slide lift. It does not change air speed or flow.
Take a read of this, CV Carb Tuning Procedures
Old Sep 22, 2014 | 04:35 PM
  #164
NZSpokes's Avatar
Go big or go home.
Going 52 idles and 198/200 mains.
Old Sep 22, 2014 | 05:41 PM
  #165
you wanna bark with the big dogs you have to get off the porch
Old Sep 22, 2014 | 06:10 PM
  #166
Go big or go home.
What's funny, is since my bike is down (was sent wrong clutch), I just swapped to 52 pilots as well. We now have the exact same jetting.
The 50's were okay, but the more I played with the fuel screws the more the bike ran better with the fuel screws turned past 3 turns out. I will be able to dial it in better once on the road again, but I'm sure it will run great with the 52's.
Old Sep 22, 2014 | 06:16 PM
  #167
NZSpokes's Avatar
Picking up the jets tonight. Will fit tomorrow night.
Old Sep 22, 2014 | 06:35 PM
  #168
I can't wait for you to feel the difference when the carbs are dialed in and the power is instant (from any RPM) and then run through the RPM's up to redline
You'll love it man.
Old Sep 23, 2014 | 03:28 AM
  #169
NZSpokes's Avatar
Ok I have a fault. When cruising at 60mph she shuts down like she is running out of fuel. If i have to stop, few seconds later its fine. Starts and goes fine.
I can and have done a good few full throttle runs to 100mph. Does this no problem.
If I open the fuel cap it does not seem to change. I have checked the tank vent line and blown air through and its clear. I drained the carbs, no water etc. When I restarted the bike I just poured about 20mls of fuel down each choke. It fired up immediately and settled to a nice idle. So its not fuel delivery via the petcock.
What I did do a few weeks ago was remove the carb vents that go into the airbox and put some light mesh over them. Mainly to make removing and refitting the airbox faster. Is there a chance this causing it?
Im running out of ideas. Rest of the time it runs well.
Got my jets now.
Old Sep 23, 2014 | 04:40 AM
  #170
check the diaphragm in the fuel petcock. I tore two over the years, identical symptoms.....
Old Sep 23, 2014 | 04:49 AM
  #171
NZSpokes's Avatar
I had been kinda thinking that. I can't get them here. I have to import them. I have a track day in a week. Can I jam it open so its constant flow? So I can track day? Then replace it when parts turn up?
Old Sep 23, 2014 | 06:24 AM
  #172
RoadManiac's Avatar
European Member
my understanding off lifting the needles is that when you give it throttle fuel is entered earlier in the carb body then with low needles, how can lifted the needles give more fuel ?
Old Sep 23, 2014 | 10:14 AM
  #173
jerryh's Avatar
I've cut out the diaphragm before. Leaving the outter part intact to serve as a gasket. Plug the vacuum line
Old Sep 23, 2014 | 10:34 AM
  #174
NZSpokes's Avatar
Because the needle is tapered, the higher it is the more it can flow.
Old Sep 23, 2014 | 10:36 AM
  #175
NZSpokes's Avatar
Thanks man. Will try another place today local to order a kit. If I cant I will cut it and order from eBay.
Old Sep 23, 2014 | 11:35 AM
  #176
RoadManiac's Avatar
European Member
yes i agree, but at full slide lift it will get the same fuel amount no matter how much the needle is lifted, so on low and midrange it will get more fuel never really thought it about it like that
... anyway those jets seem quite wallet draining only for that reason i would hope it would run like crap,
also different fuel quality would play a role to what is it that your running on down there ?
Old Sep 24, 2014 | 01:55 AM
  #177
NZSpokes's Avatar
We are 3 for 3.
Holy F%#$
Old Sep 24, 2014 | 03:00 AM
  #178
NZSpokes's Avatar
You were bang on. Was ripped. I have disabled it now. New parts ordered.
Cheers
Old Sep 24, 2014 | 03:11 AM
  #179
NZSpokes's Avatar
So I just need to sort out the bottom end and cruise. Mid and top is stunning. Im on 2 and 2 1/4 turns out on my idles. Will add half a turn tomorrow. Bit surgy on part throttle. But the rest. WOW. And the sound. WOW.
I dont want more power than it now has.
Thanks to the pioneers of this mod. It works.
Old Sep 24, 2014 | 08:19 AM
  #180
Cheers
yes, well, I've been known to be right on occasion...... glad that is the sole extent of your problem, and not something worse......
