Jetting is it worth it
Old Mar 31, 2007 | 08:52 AM
FRANKSVTR's Avatar
FRANKSVTR
I was thinking of jeting my 02 hawk all I have done to it is a bafflectomy but it does seem pretty lean. Would it be worth it to jet the bike? If so what jets do you guys think I should start with? Thanks guys ...
Old Mar 31, 2007 | 10:15 AM
cliby's Avatar
it depends. do you like learning about your bike? do you like practicing taking your tank, airbox, carbs off so many times you can do it in your sleep and begin to have your family time you do it, pitstop style? Do you enjoy frustration? If all that is yes, then definitely go for it.
seriously, if you haven't altered anything on the intake or exhaust side there probably isn't much to be gained, and potentially some loss. Not sure what you mean by it seems to run lean however. If it isn't running perfect, that is different.
Old Mar 31, 2007 | 05:12 PM
I think you can get by with adjusting the mixture screws (this is like the 4th post today I've mentioned this ), shimming the needles .040" (small washers), and a good carb sync.
andy9743
Feb 13, 2008 09:43 AM
gssbmm
Sep 26, 2007 10:16 AM
V4VTEC
Apr 16, 2007 01:45 PM
Anto
Mar 5, 2007 04:41 PM
mikstr
Jan 8, 2007 05:56 PM
