jetting question
Old Dec 7, 2006 | 01:48 PM
superchicken99's Avatar
superchicken99 is on a distinguished road
jetting question
whats up everyone. have a 99 superhawk, high mount leo's k&n and a dynojet jet kit. cant seem to find the right jet combo. even with the smallest jets the carbs are dumping way to much fuel. i've had the off countless times and cleaned every inch of them and floats are good.
Anyone have and ideas? Could the TPS be off? Thanks
Old Dec 7, 2006 | 03:46 PM
2000superhawk's Avatar
2000superhawk is on a distinguished road
Ive got the exact setup...i found it ran best using the stock filter(it ran like crap with the kn)180front/185rear..clip in the forth position, using the stock spacer and the DJ one provided and 2.25 turns out of the air screw. its still not perfect but it does run much better then stock though not as smooth form 1500 to 3000. It sll needs some refinement..not quite sure what to do with out a dyno
hope this helps
Old Dec 7, 2006 | 04:00 PM
I noticed that it ran better with the stock filter too. thanks
Old Dec 7, 2006 | 10:30 PM
2-2.25 turns on the mixture screws and use the stock #45 idle jet.
JDH5830
Mar 26, 2011 02:56 PM
LYCAN
Dec 9, 2008 01:13 PM
mikecronis
Dec 22, 2007 12:34 PM
Involute
Oct 4, 2007 06:16 AM
bluethunder
Jun 1, 2007 06:29 AM
