Jet kit installed, now no power
Old Jun 7, 2008 | 03:35 PM
rhorsley's Avatar
rhorsley is on a distinguished road
I just installed a used set of Jardine High mount cans and mid-pipes. At the same time, I jetted the carbs (Dynojet), replaced the spark plugs, replaced the stock air filter with a K&N, and blocked off the PAIRs with the TPO kit. I'm pretty sure I followed the instructions in the Dynojet kit exactly. After replacing the main jets (190 rear, 185 front) I used the tool included in the kit to adjust the fuel mixture screws 2 1/2 turns out. I took it for a very low speed drive through my neighborhood and everything seemed OK. But when I went to really open it up, there is NO power. Any help on what I missed?
Old Jun 7, 2008 | 03:40 PM
PVLIR?
Petcock shut?
Did you block off all vacuum and airbox holes from the PAIR removal?
Is it stumbling, running on one cylinder, bogging, or just plain doesn't have power?
Old Jun 7, 2008 | 03:51 PM
rhorsley's Avatar
Sorry, I have no idea what PVLIR means. I did several searches, but all addressed issues that I think don't apply here. I re-opened the petcock and capped both the airbox hole and the t-connector from the PAIR control small hose. It boggs down big time. It seems to rev just fine in the garage, but under load in gear it just boggs down.
Old Jun 7, 2008 | 05:58 PM
rhorsley's Avatar
I searched some more and found some talk about one of the slides not operating. I pulled the tank and airbox again and, wouldn't you know it, the front slide was not operating at all at any RPM. I pulled the slide and checked the diaphram finding no damage. I re-installed it, making sure the sealing edge was properly in the groove. I hooked up the tank and started her up and voila! Slide action!! I'll follow up with a report after a test ride.
Old Jun 7, 2008 | 06:05 PM
superbling's Avatar
That front slide is an evil bitch, I tells ya'!
Old Jun 7, 2008 | 06:27 PM
jbaxx's Avatar
Honducati
Been there, done that. Gotta get the diaphrams installed correctly. If they leak, you get no action.
Old Jun 8, 2008 | 10:14 AM
rhorsley's Avatar
Amen!! Well, it needs some fine-tuning to get the mix right since I'm running a little rich now, but she's back to standing up in 1st gear. It's close in 2nd, but that will come with the fine-tuning. Can anyone recommend a good shop in the Temecula area with a Dyno?
jefejrs
Mar 10, 2013 02:19 PM
awg13
Jul 26, 2010 09:54 PM
EngineNoO9
Jun 17, 2006 09:59 PM
ericbrinton
May 16, 2006 12:03 PM
02MONSTERHAWK
Apr 13, 2006 09:34 AM
