I searched, but no help
Old Mar 17, 2008 | 11:40 PM
Jeepingoose's Avatar
Jeepingoose is on a distinguished road
I searched, but need help with forks
Basically I am wondering, how big of a PITA is it to redo (rebuild) the front forks of my 99SH?
I think they are a little tweaked too, need to be straightened and rebuilt.
Whats everyones suggestion?
I am ok with tools, and light work on bikes. If its a Jeep Im good, but when it comes to bikes... i can ride em, still tryin to work on em!
Old Mar 17, 2008 | 11:41 PM
http://www.ohlins.com/Motorcycle/Hid...0/Default.aspx
I found this, but the guy who had my bike a while ago already did the rear setup.
Old Mar 18, 2008 | 06:30 AM
cliby's Avatar
tweaked, need to be straightened too"
that sounds beyond what most garage mechanics could repair at least. there should be plenty of ebay parts for whatever is 'tweaked' particularly with the stock forks. How bent? are you sure the frame and steering head is OK? Rebuilding forks is not a particularly hard thing to do, provided you have the manual (online version here), but repairing bent forks is another matter. provide some specific question and I'm sure you'll get more info - also title your question to say something about forks
Old Mar 18, 2008 | 06:51 AM
superbling's Avatar
Yeah, a "tweaked" or bent fork repair is best left to the pro's. Don't know how many or if there are any in Honolulu since shipping back to the states (umm, mainland ) would be $$$.
Rebuild is fairly simple with a manual, the proper tools and a clean workspace. One tip is to break the drain bolts (hard thread lock) while still in the triples on the bike.
Old Mar 18, 2008 | 07:49 AM
L8RGYZ's Avatar
As cliby said, if the fork(s) are bent there may also be other issues. I replaced a fork on mine only to find that the lower triple tree was also bent. You pretty much will know that when you are installing the forks, because they will bind as you slide them up thru the triples if there's a problem.
Old Mar 18, 2008 | 09:56 AM
motojoe's Avatar
Sexual Daredevil
If you can work on a Jeep, you can do it. I just did my forks yesterday. New bushings, seals, springs(race tech) and oil. Plan on 1 hour per fork leg one you have them off the bike. I'll be working on my Jeep later today.
Old Mar 18, 2008 | 11:32 AM
Ok sounds good so far. All I know is that a mech at the shop I go to here on island said soemthing about them being a little off when I got my front bearings replaced right after I bought it.
I think I need new bearings again, so im pretty sure they are "tweaked"
Old Mar 20, 2008 | 08:55 PM
There are shops that will straighten the tubes, but only steel ones. With our forks, generally they are the only ones that bend anyway.
Old Mar 23, 2008 | 10:38 AM
autoteach's Avatar
easy way to check and see if the triple clamps are off. turn to full lock both ways and check your handlebar clearances. If they are the same and you have tracking issues, bent forks. If they are different, fix and re-evaluate. As for rebuilding forks, its easy. The worst part is pounding the seals in if you do not have the tool.
Old Mar 24, 2008 | 05:09 PM
...The worst part is pounding the seals in if you do not have the tool.
PVC tubing (cut in half lengthwise) and a hose clamp, baby! Won't scratch the tubes like the metal seal drivers. You use the weight of the male slider to pound 'em in.
1100russ
Jan 9, 2015 08:38 PM
SpeedieGTI
Oct 22, 2013 07:38 AM
Red_Liner740
Jul 20, 2008 12:51 AM
EngineNoO9
May 16, 2006 08:20 AM
superbling
Dec 21, 2004 08:54 PM
