I searched, but need help with forks
Basically I am wondering, how big of a PITA is it to redo (rebuild) the front forks of my 99SH?
I think they are a little tweaked too, need to be straightened and rebuilt. Whats everyones suggestion? I am ok with tools, and light work on bikes. If its a Jeep Im good, but when it comes to bikes... i can ride em, still tryin to work on em! :rolleyes: |
http://www.ohlins.com/Motorcycle/Hid...0/Default.aspx
I found this, but the guy who had my bike a while ago already did the rear setup. |
tweaked, need to be straightened too"
that sounds beyond what most garage mechanics could repair at least. there should be plenty of ebay parts for whatever is 'tweaked' particularly with the stock forks. How bent? are you sure the frame and steering head is OK? Rebuilding forks is not a particularly hard thing to do, provided you have the manual (online version here), but repairing bent forks is another matter. provide some specific question and I'm sure you'll get more info - also title your question to say something about forks |
Yeah, a "tweaked" or bent fork repair is best left to the pro's. Don't know how many or if there are any in Honolulu since shipping back to the states (umm, mainland :) ) would be $$$.
Rebuild is fairly simple with a manual, the proper tools and a clean workspace. One tip is to break the drain bolts (hard thread lock) while still in the triples on the bike. |
As cliby said, if the fork(s) are bent there may also be other issues. I replaced a fork on mine only to find that the lower triple tree was also bent. You pretty much will know that when you are installing the forks, because they will bind as you slide them up thru the triples if there's a problem.
If you can work on a Jeep, you can do it. I just did my forks yesterday. New bushings, seals, springs(race tech) and oil. Plan on 1 hour per fork leg one you have them off the bike. I'll be working on my Jeep later today.
Ok sounds good so far. All I know is that a mech at the shop I go to here on island said soemthing about them being a little off when I got my front bearings replaced right after I bought it.
I think I need new bearings again, so im pretty sure they are "tweaked" |
There are shops that will straighten the tubes, but only steel ones. With our forks, generally they are the only ones that bend anyway.
easy way to check and see if the triple clamps are off. turn to full lock both ways and check your handlebar clearances. If they are the same and you have tracking issues, bent forks. If they are different, fix and re-evaluate. As for rebuilding forks, its easy. The worst part is pounding the seals in if you do not have the tool.
(Post 156857)
...The worst part is pounding the seals in if you do not have the tool.
