How much should I shim my needles?
Old Jun 22, 2006 | 05:21 PM
Speed_Demon's Avatar
Friday night I'm headed out to the drag strip and for the first time will be timed. I want to be bring my A game so along with uncapping my exhaust I'm going to remove the air cleaner. The bike will be trailered to the track and carefully watched as so no dust gets in.
I'm running stock jets and don't have time to order a kit. I plan to shim the needles to give me the extra fuel I'll need. How much should I shim the needles? Someone mentioned washers can be purchased at Radio Shack to shim the needles. What do I ask for, and how do I know what thickness they are?
Old Jun 22, 2006 | 06:53 PM
Scooberhawk's Avatar
Seņor Miembro, Ay Caramba
I have a feeling your valuable input is gonna start with "I wouldn't tell you to do this, but if you reeeally want to then..."
Old Jun 22, 2006 | 06:59 PM
cb21983's Avatar
cb21983
use any washers that fit the needle tightly. I shimmed my needles .020 and it works awesome with my setup.
Old Jun 22, 2006 | 07:03 PM
EngineNoO9's Avatar
i'm betting the removal of the air cleaner will make the preformance worst not better
Old Jun 22, 2006 | 07:06 PM
Usually removal of an aircleaner can only help unless the airbox is removed with it. I'm leaving the entire box intact. The only performance problem I can see is the lean condition. Besides I'm not pulling a K&N, its a dirty stocker.
Old Jun 22, 2006 | 07:20 PM
EngineNoO9's Avatar
resonance will change. plus shimming wouldn't compensate enugh. you'd need diff jets
Old Jun 22, 2006 | 07:33 PM
The resonance may change but we're talking about a sound wave which has more to do with airbox volume rather than internal air restriction. The deal is I race tomorrow and I need the bike to be its best and I can't get jets on such short notice. I'm only going to put like 5 miles on the bike before setting it back to stock. If I can get 5 more hp but have to run it lean I don't mind.
I'm not trying to be argumentative. I appricate all the input.
Old Jun 22, 2006 | 07:34 PM
I wish I had a couple weeks in which case I would do it right with a dynojet kit running 190/185 and a K&N filter.
Old Jun 22, 2006 | 07:59 PM
EngineNoO9's Avatar
I understand what you're doing but I don't see you gaining 5hp at all. maybe a 1hp gain at most
Old Jun 22, 2006 | 08:01 PM
Hm.. I thought you were gonna take the top off the airbox. Well, that's not so bad after all. Not that I'd condone it or anything...
Unzie57
Feb 3, 2013 05:58 PM
Gtrain00
Jan 12, 2009 09:38 PM
CNI Dawg
Nov 13, 2005 05:47 PM
wood
Apr 22, 2005 11:51 AM
ClevelandSuperhawkRumble
Mar 25, 2005 01:27 PM
