How to build fork attachments
Old Feb 26, 2009 | 05:22 PM
Truckinduc's Avatar
So I just built a steering stabilizer fork mount. Ive decided to do a writeup on it.
The first step is always to make a pattern of the part to be made.
My forks are 41mm, so I made the hole the appropriate size.
then you transfer the part to the appropriate piece of material.
In my case thats a piece of 3/4 aluminum. I could have gone thinner but I want this mount to be extra strong.
There will be one pinch bolt. To aid drilling for the pinch bolt make a perpendicular surface. In this picture its the surface the piece is sitting on.
This helps you drill a straight and true hole. It helps if you punch where you want the hole, This will keep the bit from walking.
Drill the appropriate undersized hole for the tap you will use.
next I used a bandsaw to cut out the hole. The circle I drew was the size I needed. I cut to the inside of the pencil line to make the hole a little smaller.
Then I use a flap wheel to smooth out the saw marks and enlarge the hole slightly until it snugly fits the fork tube.
Do a little at a time until it fits snug. I made it fit very tight because this mount will have alot of force applied to it.
Part 2 coming as soon as pics upload
Old Feb 26, 2009 | 05:23 PM
Truckinduc's Avatar
Now you find out your bolt size, and drill it out untill the pinch bolt cut. This lets the bolt only thread into the other side of the piece, pinching the clamp closed on to the fork.
now you can cut off the perpendicular surface
now I re copy the pattern on to the piece since I handled it so much the lines disappeared.
Now you can cut out your full shape.
and compare to your pattern
Old Feb 26, 2009 | 05:24 PM
Truckinduc's Avatar
center punch where the bolt will mount.
then find your bolt size again, and drill it out.
and you get this.
anyone see the problem yet?
ok well here it is
so I did some more bandsaw work and ended up with this.
Truckinduc's Avatar
I forgot to take more pictures of the piece, but I will.
Here are the pics of what the part does.
Old Feb 26, 2009 | 05:25 PM
Truckinduc's Avatar
Next Ill sandblast the part and paint it black.
You can take the principals here and make headlight brackets, or anything you want to mount to the fork tubes.
The tools needed to make these are a bandsaw, drill and a hand file.
Old Feb 26, 2009 | 05:32 PM
SlowHAWK's Avatar
Nice job.... I like your enthusiasm in just making what you need!!!
J.
Old Feb 26, 2009 | 05:50 PM
finepooch's Avatar
nice recovery on the bolt being too short/bracket being too thick.
still love that bed liner on the frame!
Old Feb 26, 2009 | 06:02 PM
Truckinduc's Avatar
Yep I knew that was going to be done the entire time. Im gonna go to the shop right now and make it look even better.
Old Feb 26, 2009 | 06:03 PM
g_clarke_2008's Avatar
You amaze me truck, I can't even upload the photos let alone build the stuff that you do!
Old Feb 26, 2009 | 06:24 PM
j shizzy wizzy's Avatar
mildly retarded
exactly what brand and type of bed liner is that stuff? is it hard like rhino liner? or is it softer and easier to scratch?
Old Feb 26, 2009 | 06:36 PM
RCVTR's Avatar
that's good old-school fabrication.
I cringe at the thought of a saw-cut flapper-wheel hole for the clamp bore. In my mind, it should be a bit more precise.
But there I go, thinking again. It'll probably work just fine.
Good use of the tools you have available.
Old Feb 26, 2009 | 07:22 PM
SlowHAWK's Avatar
That was my first thought as well... as I would have spent like crazy on a hole saw or cutter to make the thing... would have cost me 8x more than just buying a part... and this kid did the same thing with basic tools... guts and skills pay off sometimes!!!
Can't wait to see this bike Truck!!!
Old Feb 26, 2009 | 07:31 PM
Truckinduc's Avatar
Duplicolor brand bedliner spray that comes in a spray can
Hard like Rhinoliner but smoother
Ya I know what you mean, and I didnt feel like getting out the 4 jaw chuck for the lathe, that things a bitch and a half.
I used my calipers t see how round the hole was, surprisingly to you maybe, but not me, its very round. Plenty good for a clamp. Now I wouldnt suggest making triples this way.
Thanks man.
Old Feb 26, 2009 | 07:39 PM
reaper's Avatar
Very nice work! One thing you might do to tidy it up would be to counter sink the allen bolt head like you are doing for your CCT's.
Old Feb 26, 2009 | 07:44 PM
Truckinduc's Avatar
I just might do that.
Ill take both the triples, some brackets, and some other stuff to work on saturday and sand blast it all.
I did a little more work on the bracket and made it look better. Pics uploading
Old Feb 26, 2009 | 07:52 PM
autoteach's Avatar
what was the width on the bandsaw blade that you used? That is a pretty tight curve! And, my final question, why don't you have a cnc at home in the garage. That would have been so much easier.
Old Feb 26, 2009 | 07:57 PM
Truckinduc's Avatar
1/4 inch blade. cant cut steel with it. And it can do tighter curves than that.
our lathe is from like 1928. OLD SCHOOL
Im dreaming of CNC
Old Feb 26, 2009 | 08:06 PM
autoteach's Avatar
I imagine that even if the blade could go tighter, it probably got pretty warm. 1928, not bad. But, i gotcha beat, we have a lathe that has almost a 24"x8' capacity. its useless for almost every project. the other lathes are pretty small but could do your project easily. The problem is the two hours that you put into getting the 4 jaw setup. I had a half hour into truing my clutch basket prior to machining.
Old Feb 26, 2009 | 08:27 PM
Truckinduc's Avatar
Yep you got to take the good with the bad.
Im debating turning my flywheel on the Superhawk. I did my Ducati one on my lathe and loved it.
Old Feb 26, 2009 | 08:28 PM
Truckinduc's Avatar
more
close, but no contact.
Old Feb 26, 2009 | 08:33 PM
autoteach's Avatar
After 15k miles, I did mine. I missed my first 1-2 shift it came up so fast. I also hade the same thing happen when I corrected an air-fuel ratio problem that was causing a "pause" at 6500rpm. The thing that you will notice with the hawk (if you go radical on the amount you cut off) is that it isn't fun to putter around at lower rpms. you will get over if you are interested in "fun" riding.
Old Feb 26, 2009 | 08:39 PM
Truckinduc's Avatar
Ya thats the same deal with the monster.
You will loose some of the inertia for putting around town, but everything is a tradeoff.
Ill probably end up taking about half the weight off that the most radical ones do.
I need to look at the flywheel closer since I have it out. See if I can remove some of the outer most material.
That lathe I mentioned above, it will be the one turning every CCT I sell.
Old Feb 26, 2009 | 09:11 PM
autoteach's Avatar
You will want to leave the basket alone, even if you are tempted to cut the outer edge. The timing marks are located on that edge. The weight portion can be drastically reduced, but I wouldn't remove it all the way up to the starting sprague. I kept a .2-.25 inches of it for "centering" the sprague. I just felt that there could be some loads help by that lip. You will know what I am talking about when you see it. good luck,
Bill
Old Feb 28, 2009 | 07:51 AM
RCVTR's Avatar
Thanks man.
I was thinking boring head on a mill.
I spent several years making one-off parts for racing yachts, on a Bridgeport mill.
We would saw and sand, where appropriate, but if I needed a big, round hole, I'd bore it.
I miss those days, long as they were.
I think what you ended up with is perfectly adequate for what it is and for clamping on a thick-walled steel tube
Old Mar 16, 2009 | 06:50 PM
nath981's Avatar
nice job on the SS mount duc!
is that a gsxr SS cause I have one and it looks like the one in the pic?
I tried to mount it on the right front of the frame, but it wasn't nearly long enough.
did you ride it yet?
did you weld a tab on the triple clamp?
are you selling the clamps?
thanks, Nathan
Old Mar 16, 2009 | 06:56 PM
Truckinduc's Avatar
thanks, Nathan
Havent ridden the bike yet, or cranked it.
I welded a mounting tab on the neck or the frame, me piece I made is what attaches the damper to the fork.
Im not selling the clamps, just thought Id post a how to thread.
Old Mar 16, 2009 | 07:37 PM
nath981's Avatar
okay Duc. is that a gsxr SS? How long is it from hole mount on side to end bolt when extended?
thanks, Nathan
Old Mar 16, 2009 | 07:48 PM
Truckinduc's Avatar
Ya its off a gsxr. Ill measure it for you tomorrow.
Old Mar 16, 2009 | 08:26 PM
nath981's Avatar
that's what I thought. looks just like mine. Mine is about about 3" closed and 6" open if I remember(a few weeks ago)
i bought the SS for my xr650l because it's more squirrly the faster you go, and the mefo tires seem to ecaserbate the wiggles. maybe I can borrow your idea for the xr, I don't know.
apersheate the gitbak
nathan
Old Mar 16, 2009 | 08:30 PM
Truckinduc's Avatar
no problem. Those measurements sound close. I think all the stock gsxr ones are the same.
You can always put a tab on your frame and on the triple and get rid of the bracket i made.
inderocker
Jun 7, 2010 12:22 AM
AngryOlaf
May 25, 2010 09:39 AM
Crawdaddy
Forum Feedback
Mar 17, 2009 04:01 PM
HawkRider98
Sep 10, 2008 09:07 AM
ebulloc1
Forum Feedback
Mar 23, 2005 07:15 AM
