Curious....how many dealer shop hours to install manual cct's on a 98 SH?
Old Jan 6, 2016 | 06:24 PM
118811's Avatar
118811 is on a distinguished road
Just recently bought a 98' SH with 30K miles.
After reading all the warnings on converting it to mcct's....I am planning to take it to the dealer here in Honolulu.
Just wondering how many hours are involved to do the install.
I don't have the space or skills to attempt the job!😎
Thanks
Old Jan 7, 2016 | 12:55 AM
Cadbury64's Avatar
VTR virgin
I did it myself and I'm no mechanic. Requires the same level of access as doing a valve adjustment, so I would have guessed 2-3 hours.
Old Jan 7, 2016 | 08:28 AM
Hangfly's Avatar
It depends on if the shop plans to remove the front cover to ensure against chain skip and to check proper timing chain tension.
Or if they plan to do the front like most of us do. Which is the "finger tight" method.
Old Jan 7, 2016 | 08:07 PM
118811's Avatar
Thanks guys.
I guess I'll have to be prepared for a $400+ bill.
Per Hangfly...I'll have to ask the service dept if they will be removing front cover or just finger tightening method.
Well...$400 is better than a full top end rebuild, correct!!!
Old Jan 8, 2016 | 06:50 AM
Hangfly's Avatar
It really is pretty easy if you follow the instructions posted online in various places. But $400 isn't too bad I guess. Especially if it saves an engine, yes.
But the way I look at it, nobody cares more about my bike than I do, so I like to do the work on it.
Old Jan 13, 2016 | 03:33 AM
ZERO's Avatar
ZERO is on a distinguished road
If you do it yourself, I recommend not going the quick route. Remove everything and actually take off the rear as well as the front valve covers.
Actually be able to visually inspect that you ARE on T.D.C.
Old Jan 13, 2016 | 07:23 AM
Hangfly's Avatar
....and you can check proper play, or slack in the timing chain.
redhawk98
Sep 4, 2011 10:50 AM
viperkillertt
Jun 28, 2008 11:44 AM
Slim
Oct 25, 2007 12:35 PM
99Hawkboy
Aug 19, 2006 01:06 PM
AZZKIKER
Apr 12, 2005 09:04 PM
