Clipon Racing bars question
Old Jan 16, 2006 | 07:48 AM
CNI Dawg's Avatar
Do you run low rise clip on bars (for track days) on top of the triple clamp or below the triple clamp?
Is there even room for fairing clearance to run them under the top triple clamp?
TIA
Old Jan 16, 2006 | 08:50 AM
superhawk22's Avatar
No. If you put them under they hit the fairing unless they're heli bars. I have heli bars under for my usd forks and they just barely clear it.
Old Jan 16, 2006 | 12:59 PM
Monomaster's Avatar
Monomaster
+1 with superhawk22...
Anything mounted under the top clamp will hit the fairing. I have Gilles clip-ons mounted under the clamp with a +35mm rise allowing "just" enough clearance.
Old Jan 17, 2006 | 09:30 PM
CNI Dawg's Avatar
Re: Clipon Racing bars question
Gilles makes 41mm clip ons?
I don't supposed they have a hinged clamp do they?
Ideally I would put the clip ons on for track days & keep the VFR bars for the work commute & touring
Old Jan 17, 2006 | 09:46 PM
CNI DAWG, just a thought can you mount your vfr bars under or does something get in the way of doing that?
Old Jan 18, 2006 | 09:09 PM
Monomaster's Avatar
Monomaster
They sure do...(although I need 'em because I have Ducati USD forks on mine!)
Check here, there are two types... standard clip-on replacement:
http://www.apexleisure.co.uk/gillesclipons.htm
Or,
Adjustable type...
http://www.apexleisure.co.uk/gillesvariobars.htm
K30
Jul 20, 2011 05:32 PM
skoshere
Jan 15, 2009 10:50 AM
01SuperChicken
Jan 12, 2009 01:22 PM
StoneJrW
Apr 15, 2008 04:25 AM
wormeater
Jun 8, 2005 02:11 PM
