anybody have an accessory outlet on their SH?
Old Oct 25, 2004 | 02:40 PM
faz's Avatar
faz
faz
Even though I haven't looked at the SH for this purposes, I don't think you will have any problems connecting a "designed for motorcycle" heating gear to any recent model bike, so as long as you are not overloading the electrical system, you should be fine. (not much help, am I?)
If I were to make an accessory outlet, I would start with a simple home made design: go to a auto parts store, buy a cigarette lighter outlet, an on/off switch, and an inline fuse, and connect it directly to the battery. I would then try it out, by using my heated vest (or whatever) and go for a 1 hour ride, measuring the battery voltage before and after the ride (engine not running.) This should indicate if I am putting extra strain on the charging system or not.
Old Dec 27, 2004 | 09:05 PM
nomead's Avatar
nomead
To extend faz's point, I did the same to most my bikes, but used a relay to trip via the rear light (or some other running only circuit) so it doesn't drain the battery when the bike is parked and otherwise off. Monitor how much you draw. If I understand the R/R issue, you will actually be helping the R/R by drawing more current, and reduce the quantity of heat to be dissipated.
Old Dec 29, 2004 | 01:08 PM
dynamite996's Avatar
dynamite996
Re: anybody have an accessory outlet on their SH?
Man I'd like to see a pic of that hawk with the extra lights and stuff.
I've been thinking of adding some lights to mine, cause the stock light sucks as far as illumination goes.
Old Dec 30, 2004 | 02:22 AM
Shaggie's Avatar
Shaggie
Hey Bret - how's it going matey?
As for electrical outlets - these are about the tastiest out there:
http://www.powerletproducts.com/index.php?mid=0
no experience but come highly recommended by my IBR buddies
Shaggie
smokinjoe73
Jun 28, 2014 10:20 AM
Bandit400man
Jul 31, 2012 12:16 PM
oneshot
Jan 23, 2009 07:43 PM
DBLJ
Jun 21, 2007 06:36 PM
DBLJ
Jun 20, 2007 05:52 PM
