best place to tap into for accessory power?
Old Jun 19, 2007 | 08:57 AM
DBLJ's Avatar
DBLJ is on a distinguished road
i just bought a sirius streamer gt satellite radio and want to wire it directly into the bike,anyone know where the best place to tap into is for accessory power?i also want to add a power outlet as well so if anyone has any suggestions i would greatly appreciate it.
Old Jun 21, 2007 | 05:02 PM
joshn569's Avatar
joshn569 is on a distinguished road
you can go straight to the bat. If you want switched power i would go to the running light in the front. Make sure you at least put an inline fuse in the power outlet/.
Old Jun 21, 2007 | 06:36 PM
Aux Pwr Supply (APS)
Depends on amperage demand (given 12v) and need for ign sw slave. For more than 3a, go direct to bat w/inline fuse close. If ign sw reqd use relay and 2nd inline fuse to outlet. Inline fuse n/reqd from ign to relay.
Outlet depends on use; ie std cig liter female receptor. For multiple circuits a gang conn block or fuse panel can be mouted near bat. I've added 8 circuits this way. For low amp besides center marker light a gage lite tap is easy up front and is not pulled when fairing is removed. I probably have 6 relays scatterd stem to stern.
j shizzy wizzy
Feb 2, 2010 08:37 PM
ImitationCrab
Nov 20, 2009 03:26 AM
DBLJ
Jun 20, 2007 05:52 PM
klicks
Feb 20, 2007 04:36 PM
ChickenLover
Dec 30, 2004 07:51 AM
