954 front first ride report
Old Dec 22, 2007 | 05:30 PM
redman's Avatar
Night and day. I had a coerce and RT GVs and .85RT springs on my stockers.....now it's the 954USD forks etc, .85 RT springs, RT GVs. Much much more stable and all of a sudden, you don't even think about the front end anymore...inspires a lot more confidence. Not quite as compliant over bump stuff but better action. Meaning, I feel the bumps but they don't interfere with my riding.
I still have to fine tune settings, set sag etc but I am very glad I went thru the hassle and expense. Oh...and the braking? fugeddaboutit. Much more brake than I will ever use.
Old Dec 23, 2007 | 06:36 PM
redman's Avatar
Another ride under the belt. This time on the freeway, over the GG bridge and into "The City" for an errand. WOW...sooooooooo stable at speed. I pushed it up the hill and leaned over amidst traffic at 95mph and it felt like 65. Little bumps just don't exist, big ones get sucked up like you would imagine they should. I still have to dial in preload and damping adjustments but all in all......WOW...very glad I went thru the hassle to do it. MUCH better than stock with RT springs, Gvalves, Coerce brace etc. Whole different machine..yummy!
Old Dec 23, 2007 | 10:04 PM
Hey redman, I have contemplated that mod but a tuner friend told me it would be no good for the harsh city (all my riding). your opinion?
Old Dec 24, 2007 | 02:54 AM
Reinske's Avatar
Reinske is on a distinguished road
I can totally confirm redman, got he same fork and same brakes. Wonderful, such a great braking! Very stable to drive. Great!
@smokinjoe73: Well, if you only ride in harsh city the USD - fork isn't that much required, isn't it. I guess the stock one is good enough for city taffic... But if you still want to do this, ok. You can set the whole fork, in any way, there should be a setting for your harsh city...
And if you ride it, maybe you'll find your way out of this city... Who can say...
Old Dec 24, 2007 | 06:05 AM
SlowHAWK's Avatar
Hey Smoking Joe...
I have the RC51 forks on my bike.... I'd say if you 90% of your riding is the BQE or some other crappy NYC highway (actually aren't they all?).... staying on the stockers might not be a bad thing... but if your getting out of the city some, you'll be happy. Bottom line is, you could always put soft springs in the USD forks and you'd have just as nice of a ride, but with much better braking....
BTW.... where are you located... I'm in Mount Vernon just north of the Bronx, right near the Cross County and Hutch Parkway intersection...
J.
Old Dec 24, 2007 | 08:48 AM
redman's Avatar
Smoker.......if you could snap your fingers and your front end would magically change itself for free....then it's a no brainer. If I was using my bike for commuting and transpo and the occasional jaunt out of town, I wouldn't do it. It will cost you anywhere from $500-$1000 depending on everything. It will take some looking, bidding, buying, waiting, wrenching, photos, selling, installation, grinding of stops, new bars, possibly rebuilding of new forks, tweaking, etc etc. If you don't do your own wrenching it will cost a lot more. I like to push my bike hard in corners...all the time. I like to get to the local track every now and then $$ permitting. I did mine because I wracked up my front end at the track and had to rebuild it anyway. If I hadn't, I would've left it as it was.
I also have tweakers and tinkerers disease and can't seem to leave ANY motorcycle I own alone. So there you have it......good luck.
Old Jan 7, 2008 | 04:43 PM
fundgh's Avatar
Hey redman (and anybody else with a 954 top tripple clamp)... What did you do about the ignition switch mounting and whatever the hell goes on top of the bezel? I was able to shim it down so that the lock mechanism works, but there appears to be some missing component/ring that goes around the ignition switch. Does the little piece that screws on there fit with the SuperHawk switch, or did you do something different?
Old Jan 7, 2008 | 05:40 PM
SlowHAWK's Avatar
The 929 954 triple uses a "bezel" around the ignition lock to fill in that gap. You can pick one up off Ron Ayers if you need one. I guess the CR ignition doesn't have the labeling (on/off/etc) on it.... thats why they use that bezel.
J.
Old Jan 7, 2008 | 07:16 PM
I'm in Bklyn hts, right by the east river/Bklyn & Mnhattan bridges. All my street riding is city except a trip or 2 upstate. I race the full CCS series at Loudon(expt#73). Not too far from you geographicly but a world away. Yeah, BQU sucks but its kinda my backyard. Nice view under the promenade tho.
Old Jan 8, 2008 | 06:02 PM
redman's Avatar
I just left the open ring...if it's as easy as buying a part to snap in there, I'll do it. Otherwise I don't care much.
Old Jan 10, 2008 | 04:16 AM
Reinske's Avatar
That's it!
Leave it like it is, doesn't look too bad.
Old Jan 13, 2008 | 08:04 PM
I ordered a new ring and screws. I was able to install them without any disassembly. Total cost of parts is under $10 IIRC.
sweetriden76
Sep 22, 2009 05:20 PM
aka Yamadog
Feb 22, 2009 07:00 PM
nnjhawk02
Aug 6, 2008 11:06 AM
drew_c14
Apr 18, 2008 04:19 PM
3D02
Nov 6, 2006 09:40 AM
