Will these Flushmounts fit on my hawk?
Old Oct 17, 2010 | 01:07 PM
99Hawkboy's Avatar
99Hawkboy
I am upgrading to flushmounts and was just curious if these will fit my hawk?
Anyone using these?
http://www.chaparral-racing.com/Prod...L122-9700.aspx
Thanks!
Old Oct 17, 2010 | 01:29 PM
saige's Avatar
the boss
it will fit,it might need to be adjusted a little but it will go on,just make sure its a 3 wire signal.
Old Oct 17, 2010 | 01:43 PM
They will fit but you will need to make a couple of plates to mount them with but that is a simple job.
It does list them as dual filament, so they are 3 wire signals.
Old Oct 17, 2010 | 02:35 PM
uchi's Avatar
those look like the ones i have, i bought a set for a cbr 600, like 8541 said you need to make some plates, i used some pl premium and stuck them on like that and let them sit over night.
Old Oct 17, 2010 | 02:37 PM
uchi's Avatar
Old Oct 17, 2010 | 02:53 PM
99Hawkboy's Avatar
99Hawkboy
AWESOME! Thanks for the help guys... Ordering right now.
Old Oct 17, 2010 | 03:59 PM
ttocsmai's Avatar
I am putting mine on tomorrow because I just bought a set and waiting for the LED lights to put in them.
My question about putting these in, when the originals came out they were secured on the inside plastic pieces. Do you still need to secure those or do you just take them out? They don't seem to have a reason to be there, just to hold on the OEM lights.
Old Oct 18, 2010 | 07:15 AM
99Hawkboy's Avatar
99Hawkboy
Yeah im not 100% sure but im sure ill be fabricating a lot. I ordered an LED tail light with integrated turn signals and will be changing the undertail assembly to accept an undertail exhaust.. Pretty excited about the coming months. Going to be a lot of work but should be where i want it by December.
Old Oct 18, 2010 | 09:10 AM
Yes you need those parts as they tie the lower fairing together with the center section.
Old Oct 18, 2010 | 12:59 PM
ttocsmai's Avatar
Alright, wire to hold it on it is. Or have to figure out how to hook it to the plate that holds the lights.
Old Oct 18, 2010 | 01:51 PM
Yes they will fit fine but be sure to order the 3-wire (so the running light & TS function) LP Type 3 with amber lens' . I used double-sided foam tape for a tight fit between the fairing & units and cut a thin aluminum piece with lock washers & nuts for the back side. Oh, and buy extra bulbs which are only available from LP.
Old Oct 19, 2010 | 05:13 AM
ttocsmai's Avatar
they have an LED kit for them too, if you want to get noticed a bit more.
This is what I have on order:
http://www.customled.com/products/fl...flushmount.htm
Old Oct 19, 2010 | 06:23 AM
Bearshawk's Avatar
not to thread jack but those LED ones look HOT and custom color running lights?? yes please, same with those lights, just make a plate and bam?
Old Oct 19, 2010 | 08:18 AM
uchi's Avatar
I went with a two wire led setup in mine. Smoked lens as you can see in the pic. I didn't want them on all the time. But I've got an hid retrofit aswell so I get noticed as it is :-)
Old Oct 24, 2010 | 02:46 PM
99Hawkboy's Avatar
99Hawkboy
Ok got the turn signals in and they deffinitely wont fit... Way to big.. Guess i should have read the size of them.. Any other sites with flushmount turn signals that will actually fit?
Old Oct 24, 2010 | 03:23 PM
saige's Avatar
the boss
have you thought about doing protons,i put protons on my bike and its dam near perfect fit,its the protons for the rc51,they are led,they run correctly if you get the led flashers and you good to go.
Old Oct 24, 2010 | 04:24 PM
uchi's Avatar
protons work, anything for a cbr will work aswell. which means that cbr watsens might work too
YLTO-Superhawk
Apr 13, 2013 08:26 PM
pzurek18
Jan 19, 2009 06:15 PM
pzurek18
Nov 22, 2008 01:58 PM
azhawk1
Feb 8, 2007 06:17 PM
xxxrated
Nov 2, 2006 08:53 PM
