take a feed
Old May 3, 2008 | 07:17 AM
fishface's Avatar
fishface is on a distinguished road
take a feed
where would you take a feed from for the n+(white) and n-(yellow)
does it have to be a switched positive or a constant live
this is going on my fightered storm
thanks in advance
Old May 3, 2008 | 07:37 AM
superbling's Avatar
If the VTR sensor is like my current 96 VFR (and I think it is), the pink wire of the three wire cable is the sender, the other two are +/-.
Old May 3, 2008 | 10:00 AM
fishface's Avatar
sorry bro im still in the dark ..
Old May 3, 2008 | 10:38 AM
Waht do you mean exactly when you say "take a feed" ??? (dunno, might be that english is a second language to me...) because it doesn't make sense combined with the question about switched or live?
But those wires are supposed to be the sensor for the neutral light, ie there are one positive sensor and one negative in that multi purpose unit since different bike models have either positive or negative sensing on that (ie some use a diode, some not...)
In the case of the VTR i believe it should work by hooking up the n+ wire to the wire for the neutral sensor...
Old May 3, 2008 | 11:00 AM
superbling's Avatar
Sorry, I hadn't had my morning caffeine fix before replying. I somehow thought you were asking about the speedo' sensor.......
Not having read the instructions, I'd guess that the unit gives you a choice of hooking up the neutral indicator to a + or - feed not both. You'll need the VTR schematic to determine which one it uses. IIRC on my 96 VFR, it as a -.
Old May 3, 2008 | 12:46 PM
There is a light green wire that comes off the neutral sensor and ties in between the ECU and the fuse box. That is the N+. The neutral sensor itself is grounded to the motor so it would seem to me that any ground would work for N-.
Old May 3, 2008 | 08:49 PM
fishface's Avatar
thanks that the answer i needed
mikstr
Oct 12, 2014 12:24 PM
skycam
Aug 19, 2010 10:28 PM
EngineNoO9
Apr 12, 2007 05:36 PM
selztoad
Mar 21, 2007 08:19 PM
vmoto
Oct 4, 2006 12:51 PM
