Repair or replace?
Old Jul 31, 2008 | 07:03 AM
melow08's Avatar
melow08 is on a distinguished road
Repair or replace?
I dropped my SH in the garage, I know, and the only real damage was the left front fairing cracked right at the left turn signal. I say cracked, but it actually broke. Is this type of thing worth fixing and painting, or should I just replace it. I worry about matching the paint if I fix it and if it will still be strong enough to mount flush turn signals. Replacing cost just under 300, but it will be a color match. Thanks in advance for your input.
Old Jul 31, 2008 | 07:40 AM
supertrooper's Avatar
supertrooper is on a distinguished road
if the paint is not messed up too bad near the break, you could get clear 2 part epoxy and glue it back on. you can find it at any auto parts store for 3 or 4 bucks. get the one with the slowest cure time because the faster stuff heats up when curing and might damage the paint and plastic. somthing like 15-20 min should be fine
Old Aug 1, 2008 | 10:21 PM
filter69's Avatar
Thats Mr Dill hole to you
Same thing happened to mine when thou a crappy aspahlat parking lot and the blinker cracked my fairing. i expoyied it with a 2 part 45 min from dow thats made speciffically for
4 abs/pvc etc plastics worked great i taped the joint and waited till cured cant even see the crack unless i point it out and even then its hard and it has not came loose after numerous trips to 180 +
but YMMV
Old Aug 2, 2008 | 06:46 PM
timdske's Avatar
timdske is on a distinguished road
The color match shouldn't be a problem. I had to replace both of my fairings and they came from Honda painted perfectly. You can't tell they aren't the orignals.
Old Sep 17, 2008 | 06:41 AM
Byrdman's Avatar
Super Byrd
Where did you buy your fairing? i just broke mine too
Old Sep 17, 2008 | 06:53 AM
bcsnave's Avatar
1Liter Rider
bcsnave is on a distinguished road
Sharkskinz
Sharkskinz or Honda
Old Sep 17, 2008 | 10:15 AM
lynchie's Avatar
AZ RIDER
ohhhhhh, god, i almost went to set my bike on the stand, WHICH WAS NOT DOWN!!!!! Im sure it will happen though..
Vincent
Jun 30, 2011 12:58 PM
Generation450X
May 25, 2009 07:14 AM
Randman
May 2, 2006 04:25 PM
ta2av
Dec 3, 2005 12:45 PM
cozart02
Jul 18, 2005 08:53 PM
