PowderCoating Starter Motor Casing
Old Jan 14, 2016 | 08:44 PM
thedeatons's Avatar
I have my starter disassembled, and was planning to have the round (cylindrical) starter motor casing powdercoated. It is stripped down, but the magnets are still inside.
Only the outside would be blasted/coated/baked, not the inside.
Anyone see and ill effects of doing this with the magnets installed?
James
Old Jan 15, 2016 | 12:40 AM
Wicky's Avatar
Bear in mind high temperatures can damage & disrupt magnets (Curie temperature) and painting it more conventionally will make it easier to touch up wear & tear, chips etc.
Old Jan 15, 2016 | 04:36 AM
What Wicky said. I believe powder coating is done around 400 degrees F which is probably well above the Curie temp of the magnets used in the starter. Even approaching a magnets Curie point will have ill effects on the magnet's field strength and composition.
VTRsupersport
Mar 9, 2012 05:09 AM
7moore7
Oct 16, 2010 09:13 PM
ozzie9962
Apr 13, 2009 12:16 PM
twidge
Feb 7, 2009 05:11 AM
