Name those pipes...
Old May 9, 2011 | 01:09 PM
notquite's Avatar
notquite is on a distinguished road
Name those pipes...
I had a crazy idea...I need undertail exhaust. REAL undertail exhaust. It wasnt easy. but it happened.
Attached Thumbnails Name those pipes...-untitled1.jpg   Name those pipes...-untitled3.jpg   Name those pipes...-untitled4.jpg   Name those pipes...-untitled5.jpg
Old May 9, 2011 | 01:10 PM
skoshere's Avatar
they look like R1 pipes
Old May 9, 2011 | 01:24 PM
I was going to say R1 as well. Have you driven it yet? It could just be the camera angles, but there doesn't look like a lot of suspension travel.
Nice work though. How does it sound?
Old May 9, 2011 | 01:31 PM
notquite's Avatar
they are R1 pipes. yes. been driving it for about 2 years like this. there isnt a lot of travel so i just firmed up the suspension as much as i could stock and i dont take a rider. works just fin and im coming in at 200 pounds.
Was gonna put a SSS on but im selling BC im moving to aust. the swing arm would have lengthened the wheelbase and given waaaay more clearance i think.
Old May 9, 2011 | 01:36 PM
nath981's Avatar
looks righteous! take some side pics so we can see how you manages the pipes.
Old May 9, 2011 | 03:22 PM
notquite's Avatar
as requested
Attached Thumbnails Name those pipes...-side-front-pipe.jpg   Name those pipes...-underside.jpg   Name those pipes...-both-back-right.jpg   Name those pipes...-both-back-left.jpg   Name those pipes...-both-pipes-back.jpg
Old May 9, 2011 | 05:04 PM
evines's Avatar
How the hell did you get that to work? Even with the pictures I can't see how that fit. Good job!
Old May 9, 2011 | 05:58 PM
notquite's Avatar
Actually most of it was the original piping cut, welded, sanded, and painted w extream temp paint. The rear header normally goes down through the swing arm. I took that pipe and had it come straight out to the left muffler. Then I had the front pipe come up through. The opening the rear pipe used before.
Also did some cutting with the plastic under the seat. Fabricated a new undertail/heatshield and mounted the mufflers. To make a long story short.
Ps, R1 pipes are titanium. What a pain in the @$$. They can be welded, but its way to expensive. Much cheaper to simply cut and clamp.
Old May 12, 2011 | 05:48 AM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
Is there some sort of balance pipe between the headers? The front looks a lot longer than the rear. How does the bike go? It would seem to me that the rear cylinder will run pretty hot and the gas flows would be disrupted due to the loss of the pulse scavenging.
Old May 29, 2011 | 02:08 PM
notquite's Avatar
actually, ive had zero problems with the difference in the pipes. maybe bc theres very little back pressure, maybe just bc. i asked alot of the same questions to my mechanic before we started. in the end,i just know it workrd better than i expected.
Old May 29, 2011 | 04:40 PM
zmaniv's Avatar
Do you have dyno numbers from before and after?
HU112BU
May 21, 2015 05:37 PM
Randman
Dec 13, 2006 07:10 PM
Radiaoktiv
Nov 19, 2006 10:14 AM
Vincent
Jul 21, 2006 06:34 AM
CNI Dawg
Nov 3, 2005 09:12 PM
