Modifying Stock Seat
Old Aug 9, 2016 | 12:50 AM
Wait04's Avatar
Trevor
Wait04 is on a distinguished road
Hi There
Has anyone tried modifying the stock seat , so its comes off easier..
trev
Old Aug 9, 2016 | 05:04 AM
Yes, that''s an easy one, remove the hooks from the rear part of the seat and add either a flat plastic or aluminum or couple washers between the seat and the hook of about one millimeter thickness, that would do the job.
Old Aug 9, 2016 | 06:28 AM
Or you could just straighten (bend to a more perpendicular position) out the formed metal wire that the hooks engage. It's what I did and it fixed the same problem for me.
Old Aug 9, 2016 | 02:48 PM
Or slightly grind with a small Dremel rubber "drum" with their 120 grit cover at the contact point of the saddle hooks to where they engage the sub-frame "loops"; and then optionally touch up the hooks with a abrasion resistant coating (paint).
Old Aug 9, 2016 | 03:26 PM
Hangfly's Avatar
+1 .. He is right. Every time you hit the gas, you weight shifts the saddle to the rear, bending rearward the wire loops sticking up from the frame. Just beat them back forward to a vertical position.
Old Aug 9, 2016 | 09:36 PM
Wait04's Avatar
Trevor
Thanks Everybody...Filed small amount of Hooks & Bent the Wire Loops too.. Comes off much easier now.. Cheers
Spawnbike
Apr 20, 2014 12:27 AM
Cafe Racer
Nov 4, 2011 04:14 PM
Tweety
Jan 25, 2011 01:51 PM
ttocsmai
Nov 11, 2009 01:38 PM
marmaladedad
Jan 15, 2005 10:04 AM
