LED lights
Old May 30, 2007 | 04:42 PM
twistidd's Avatar
twistidd is on a distinguished road
LED lights
hey whats up everyone. im a newbie here to the forum. Im looking to buy some LEDs and tastfully put them within my superhawk. if i were to put 2 in the side radiator exhaust, do you think they will melt? damage to the bulb or cable. What do you guys think?
Old May 30, 2007 | 07:48 PM
xecutech's Avatar
xecutech is on a distinguished road
Since the air is coming in, I wouldn't think it would hurt it, but I am sure someone with more experience would be here to advise you.
Old May 30, 2007 | 08:05 PM
Arctic Fire's Avatar
Arctic Fire is on a distinguished road
I've often thought that two white LED's would look good in the intakes, as long as they are tasteful and the actual LED is not visible. I am sure you will get some very mixed opinions about this, but that's what Forums are for!
If you hid them behind the fairing so they lit up the rad that would look pretty neat. I am sure that Walmart makes a bar shaped LED that would snug under there pretty cleanly. There should be no heat that could damage anything in that area. What about Orange that lights with the signals? kind of a glow signal. That may be approaching ricer territory.
Let me know what you come up with for wiring and LED types.. and of course pictures, so if it looks ridiculous we won't need to do it to ours! (guinea piggy)
Old May 31, 2007 | 05:01 AM
StoneJrW's Avatar
StoneJrW is on a distinguished road
I have also been thinking about putting some type of LED in the intakes. I think it would look good.
Old May 31, 2007 | 10:27 AM
twistidd's Avatar
i didnt realize those were intakes because they are openned toward the back. that wouldnt make a great ram air intake in that case. but either way, if you idle long enough, it still would get pretty hot in that area. wouldnt you guys think?
Old May 31, 2007 | 12:00 PM
Zedicus's Avatar
Zedicus is on a distinguished road
which side are we talking about now?? air comes in the radiators from about wher the front tire is and passes out about where yur legs are.
Old May 31, 2007 | 07:54 PM
twistidd's Avatar
im talking about where your legs are. although i was intending on put some on the front under the headlight also, and i think that may be the intake that was previously mentioned. sorry if i wasnt clear
Old Jun 1, 2007 | 07:10 AM
twistidd's Avatar
any other inputs?
Old Jun 2, 2007 | 02:26 AM
Yes the Intakes I was referring to are at the front, and the "Radiator vents" facing backwards are called..... well, i'm not sure. outflow Vents? either way, I can't remember if it gets hot in the vents or not, I don't think it does, but I will check next ride.
Old Jun 2, 2007 | 10:02 AM
RickB's Avatar
LEDs are pretty hearty - they hold up pretty well and should survive indirect heat.
Old Sep 27, 2011 | 03:34 AM
tomzxt's Avatar
Light Cycle Expert
It would take some pretty serious heat to melt the LEDs or neon tubing. I have used both on my cars and motorcycles. When running the wiring make sure to choose the location carefully. Like posted above, indirect heat won't affect it but direct heat will.
Keep in mind to tell any service techs that you have those lights on your motorcycle if you get work done. If you don't they will destroy the wiring when removing fairings and usually tell you tough luck since you didn't let them know.
Old Sep 27, 2011 | 08:13 AM
Big Shepp's Avatar
Big Shepp is on a distinguished road
Are you talking about putting the front blinkers where they are on this one?
Old Sep 27, 2011 | 11:36 AM
CrankenFine's Avatar
Exclamation
It's a really old thread guys... can't say I've never done this myself.
Old Sep 27, 2011 | 11:45 AM
kj4kym's Avatar
kj4kym is on a distinguished road
ive done it. leds can stand very high heat no problems at all.
Old Sep 27, 2011 | 05:42 PM
finepooch's Avatar
leds? really?
Old Nov 3, 2011 | 04:12 PM
Wild Bill's Avatar
Wild Bill is on a distinguished road
I know this is an older thread but I put LED strips that I bought at Walmart in the same area and by my exhaust on my 08 VFR and never had any problems with them melting or falling off
Old Jan 22, 2012 | 12:44 PM
theosagekid's Avatar
theosagekid is on a distinguished road
messing about with leds, turnsignals & etc.
Do you have any idea how those lights were put in the "ports" and what happened to the original turnsignal ports?
I'm hoping to do the gixxer integrated mirror conversion but I'm at loose ends as to what to do with the holes that the OEM signals go through.
I've considered putting in some kind of flush-mounts and wiring them to be running lights only (using LEDs, just to keep the strain on the electrical system down.)
Unfortunately I haven't ever seen a teardrop-type front turnsignal that didn't make me think "geez, how butt-ugly do they want me to make my bike?" and all of the flush signals I've seen look like somebody just slapped a piece of amber plastic over the port and walked away.
I don't have the means to replace the stock bodywork or have someone do bodywork modifications along with a new paint job.
Ideas, anyone?
Old Jan 22, 2012 | 12:54 PM
That bike has aftermarket fairings, custom made with the upper and lower as integrated panels, as well as not having the stock holes cut... So not very similar to your situation at all...
My suggestion, Peugeot 306's have blinkers/position lights that fit the hole very well... Stock parts are incandescents, but there are LED aftermarket parts available...
Old May 20, 2012 | 11:07 PM
[QUOTE=Tweety;323395]That bike has aftermarket fairings, custom made with the upper and lower as integrated panels, as well as not having the stock holes cut... So not very similar to your situation at all...
Duhhhh.... single sided swingarm should have screamed "majorly modded."
Thanks Tweety
Old May 23, 2012 | 02:19 AM
superfast's Avatar
superfast is on a distinguished road
Nope.Led voltage is very low.How can they melt?
Old May 25, 2012 | 02:50 PM
Sawzall86's Avatar
When in doubt, C4
Sawzall86 is on a distinguished road
I think he was talking about radiant heat from the motor or radiators when he first asked this way back in 2007.
rafbo
Jan 3, 2019 02:38 PM
theosagekid
Jan 22, 2012 01:33 PM
Pitt3265
Sep 6, 2009 12:59 PM
SuperMike
Jul 14, 2008 05:27 AM
PHPERFORMANCE
Sep 19, 2006 07:14 PM
