headlights?
Old Oct 2, 2007 | 05:34 PM
macworld's Avatar
macworld
headlights?
my brights are really NOT bright. my regular lights are brighter. does anyone else have this problem? is it normal, or are my lights not aimed right? i would like to buy some better brights. any suggestions?
Old Oct 2, 2007 | 06:11 PM
Hotbrakes's Avatar
I had a similar problem when I first got my SH. The beam was pointed too high which made the low very nice but the high was shooting off to the horizon. There are two 10mm screws on the back of the housing on opposite corners (one low and one high). I just cranked on those til I thought the beam had lowered some and its fine now. Before I did that it was like you said, the high was dimmer than the low. Put it on the stand in your garage and dim the lights, pick a reference point and start adjusting. I think the bolts also control left to right so if you move one, you have to move the other to keep it straight. Good luck!
Old Oct 16, 2007 | 12:00 AM
Anto's Avatar
Anto is on a distinguished road
HID retrofit. yeee haw
https://www.superhawkforum.com/forum...ad.php?t=10992
Old Oct 16, 2007 | 12:06 AM
Besucher98's Avatar
Besucher98
that looks bright!
Old Oct 16, 2007 | 02:00 PM
Macworld,
Make sure the bulb is installed correctly. Sometimes they can be mounted upside down or one of the tabs doesn't align to it's associated slot.
DBRBILL
May 27, 2008 08:38 PM
dynamite996
Oct 26, 2007 12:41 PM
viperkillertt
May 15, 2007 07:42 AM
Besucher98
Jan 1, 2006 08:39 PM
ClevelandSuperhawkRumble
Mar 22, 2005 08:49 PM
