View Poll Results: VTR Of The Month - November 2010
cliby
21
42.00%
Tweety
28.00%
smokinjoe73
18.00%
David86
12.00%
Voters: 50. You may not vote on this poll
VTR Of The Month - November 2010 - WINNER: cliby
Old Nov 1, 2010 | 01:18 AM
Congratulations to cliby for winning the November 2010 VTROTM!
https://www.superhawkforum.com/forum...06&postcount=2
A BIG thanks to everybody who participated in October's VTROTM, and an especially big thanks to AngryOlaf for being our anchor nominee for the better part of the year. If you did not win, be sure to get your nomination in again this month for your chance at SHF fame and glory!
VTROTM Rules:
  1. Picture (REQUIRED) 3 Max! Please limit picture(s) size to 1024 x 768.
  2. Open to all Super Hawk Forum Members.
  3. You are limited to 1 entry per month.
  4. You can only nominate your own VTR. (projects, daily riders)
  5. Candidates will be nominated up until the 15th of the month or when 15 nominees have been made, whichever comes first.
  6. A poll will then be set up (on the 16th if less than 15 nominees) for everyone to vote for VTROTM for that month and close on the last day of the month.
  7. All participants who vote will get to vote only once per month so make it count!
  8. Negative comments, criticism, harassment, and all around bad manner wont be tolerated.
  9. If you have won VTR of the month, you cannot enter your bike for 12 months.
  10. In the event of a tie, a 7 day poll will be set up to break the tie.
  11. Rules subject to change / amendment at any time.
  12. Description of a candidates bike should include the following If available:
  • owners name
  • year
  • color(s)
  • modifications
  • tech specs (if any)
Nominee's:
cliby - https://www.superhawkforum.com/forum...06&postcount=2
Tweety - https://www.superhawkforum.com/forum...73&postcount=6
smokinjoe73 - https://www.superhawkforum.com/forum...12&postcount=8
David86 - https://www.superhawkforum.com/forum...4&postcount=12
Attached Thumbnails VTR Of The Month - November 2010 - WINNER: cliby-p1080421-1.jpg
Old Nov 1, 2010 | 06:24 PM
cliby's Avatar
OK, I'll put mine in again.
2000 Superhawk. About a decade of love sweat and tears into it, lots of revisions/misteps along the way. Its a blast to ride.
Major changes I can recall:
Stage I moriwaki cams/pistons/full exhaust
Ported heads/3 angle valve job
HRC ignition and carb mods
Moriwaki rearsets
RC51 Front end
OZ wheels
JMC Swingarm
Penske Shock
Radial brakes
Nava Tailpiece
Superbike fatbars
Other little things I forgot
It puts out rw 120hp, is much lighter, handles great and is more comfortable. A couple of pictures and the last one from about 5 years ago as a reminder to thank this site and all the expertise and help which allowed me to do a lot of this I wouldn't have tackled myself. I have learned a ton and enjoyed modifying and riding this bike way more than I would have simply buying a newer sports bike.
Old Nov 1, 2010 | 06:31 PM
t-dogg's Avatar
Wow! Hard to compete with that
Old Nov 2, 2010 | 10:02 AM
Old Yeller's Avatar
He already has me beat....and it's yellow too. I'm ready to vote!
Old Nov 2, 2010 | 11:26 AM
FL02SupaHawk996's Avatar
Fastest Color
Cilby, you r killing the competition with that monster of yours!
Old Nov 2, 2010 | 03:17 PM
Guess someone has to make a stand for Team Red then...
Probably should note though that the pictures are more than a year out of date... I have rebuilt a lot since then... I really, really need to take some new one's...
The list of mods is pretty long... These are the highlights (ie what I remeber doing... There are probably a few more that I have forgotten...)
CBR 1000RR fork:
- CBR 1000RR USD fork (Reworked with Öhlins internals)
- CBR 1000RR wheel with 320mm rotors
- CBR 1000RR complete brake (Radial M/C, radial calipers)
- CBR954/929 triple tree
- ConvertiBars adjustable clip-ons
- Moved the radiators to make room for the fork
CBR 1000RR instrument cluster:
- CBR 1000RR temp sensor (Turned it down and made new threads)
- Integrated gear indicator (build and design by me)
- Integrated fuelgauge (In progress) & charging indicator
- Speedohealer (v4)
RC51-SP2 swingarm:
- RC51-SP2 swingarm with custom welded lower link mount (Idea from hawkter996)
- CBR F4i rear shock (Modified with heavier spring and Racetech Goldvalve by Jamie Daugherty)
- RC51-SP2 rear caliper & caliper mount
- CBR 1000RR rear wheel & sprocket (6" with a 17/190/55)
- Custom mount plate for rearset at the pivot bolt
- Custom rearset (parts from cheap eBay set and some custom made)
Fairing:
- Dark tinted DB screen
- CBR 954 OEM hugger
- Mototeck undertail
- GSXR Mirrors, with singals in them (Completely custom made mount)
- T-Rex sliders
- Delrin sliders on both wheel axles
Electrical:
- HID projector (Nissan G35) High & low beam.
- Brake light modulator (build and design by me)
- R1/R6 Regulator/Rectifier Swap
- Peugeot 206/307 flush mount indicators
- LED plate light in Mototeck undertail
- LED taillight Retrofit (Idea from haknslash)
- 8 pack of A123 cells replaced the battery
- Moved ECU & CDI to the battery box with the new smaller battery
- Improved wire harness with more ground points
- Suzuki Hayabusa handlebar controls (Gives me warning lights and moves the light switch to above the start button, great for killing the HID before cranking)
Engine:
- Custom cams (equivalent to Moriwaki Stage 1)
- Ported & flowed heads
- Lightened flywheel
- BMC street airfilter
- FloCommander
- Aluminum velocity stacks
- DIY Manual CCT's (bolt through drilled out stock CCT body)
Misc:
- Sargent seat
- Aluminum front fairing stay & rear subframe (custom made by me)
- Jardine Aluminum high mount slip-on, removed muffler mount from stock rear footpegs and spaced them out
- 16/42 gearing
- Short throw throttle
- Custom made mount for my disc lock (I got tired of opening the seat to store it)
Old Nov 2, 2010 | 06:52 PM
sethday's Avatar
sethday is on a distinguished road
Man it just got really interesting. I am gonna ponder on this one.
Old Nov 2, 2010 | 11:00 PM
OK so I am in but need to enter more pics later if thats legal. (or even if it isn't). I only know how to attach the small pics so if anyone can clue me in I will put on bigger ones.
Mods: >Single sided swingarm (VFR800)
>CBR1000rr front end (forks, wheel, brakes)
>Mario Nava carbon fiber bodywork
">Deville" custom exaust
>Apex riser bars
>Oakley 3 grips (few know what these are, but you'll appreciate it if so)
>LED mirror turn signals
>Undertail with LED signals
More pics to come
Attached Thumbnails VTR Of The Month - November 2010 - WINNER: cliby-sss-8.27.10-001.jpg   VTR Of The Month - November 2010 - WINNER: cliby-sss-8.27.10-002.jpg   VTR Of The Month - November 2010 - WINNER: cliby-sss-8.27.10-003.jpg   VTR Of The Month - November 2010 - WINNER: cliby-sss-8.27.10-004.jpg
Old Nov 3, 2010 | 04:55 AM
I'm not trying to be stingy... But the rules are max 3 pictures... I could add more to show details but I have to leave them out...
The best way to get reasonable sized images (like mine) is to upload them into the forums gallery, and then just copy&paste the link that's provided below the picture...
If you want the images larger than that, you need an outside host to link them in...
Old Nov 3, 2010 | 05:35 PM
trident00's Avatar
trident00 is on a distinguished road
Wow guys.....one hell of a bike of the month challenge. All very fine examples of highly modded steeds. I'd say you all are winners.
Good luck to you all.
Cheers, Walt
Old Nov 3, 2010 | 05:48 PM
Sweet rides, all of them. Nice work gents!
Old Nov 15, 2010 | 09:25 AM
David86's Avatar
David86 is on a distinguished road
Here is my contribution! It's an orange -99 with black colored seat cover and black belly pan from Pyramid plastics. The mounted windshield is a black tinted one from Powerbronze. There is also a highpipe system from MIG, front and rear LED turn signals and a carbon hugger.
The technical specification it is the same as it was from the factory.
Regards,
David D
Attached Thumbnails VTR Of The Month - November 2010 - WINNER: cliby-dsc_0012.jpg   VTR Of The Month - November 2010 - WINNER: cliby-dsc_0009.jpg
Old Nov 15, 2010 | 09:40 AM
The "clash of the titans" poll is up, get those votes in!
Old Nov 15, 2010 | 12:50 PM
Old Yeller's Avatar
We need an "all of the above" button this month!
Old Nov 15, 2010 | 04:16 PM
whozit's Avatar
not-so New Member
whozit is on a distinguished road
+1 with Yeller. These handsome steeds make my stocker want to hide in the garage! Kudos to all of you!
Old Nov 15, 2010 | 04:30 PM
Perhaps a tourney bracket is in order...
Old Nov 16, 2010 | 02:06 AM
102dals's Avatar
'Joe,
Is this Brian Light's old bike, it looks the same except for the paint. I really like the SSA mods.
Old Nov 18, 2010 | 09:46 PM
VTS's Avatar
VTS
OCMD honorary member
Nice to see everyone again, best of luck.
Hard to believe it was a year ago that I was in this race (NOV VTROM)
Time flies.
Old Nov 18, 2010 | 10:02 PM
I agree with the "all of the above" option. Especially cliby, Tweety and joe...three of the real senior guys, with some major mods.
I vote for a 3-way tie. I can't pick just one of these labors of love.
I did finally pick one...but I'm not tellin'.
Old Nov 24, 2010 | 07:00 PM
RWhisen's Avatar
Former Superchicken Owner
This is battle of the titans month!
Old Dec 3, 2010 | 09:22 PM
Nice VTR's all around! Congrats cliby, well deserved!
Old Dec 6, 2010 | 06:01 AM
motokraft's Avatar
motokraft
motokraft is on a distinguished road
great to see all these different takes on the vtr every month , seems to be a highly modified bike among owners , good to see the individual stylings too , it gives them a personality , (dunno what my ones is still ,, good stuff !!
Old Dec 6, 2010 | 05:05 PM
cliby's Avatar
wow, surprised! thanks guys, I agree they are all great. tweety's bike is amazing and i love the orange david.
bill
inderocker
Jan 1, 2011 02:50 PM
inderocker
May 5, 2010 08:10 AM
inderocker
Apr 1, 2010 11:59 PM
inderocker
Feb 1, 2010 08:16 AM
inderocker
Dec 3, 2009 08:38 AM
