Project Superhawk motard "SuMoHawk" begins
Old Oct 31, 2009 | 03:33 PM
Just_Nick's Avatar
Who are you?
As some of you read, I decided to try to convert my Superhawk into a "Motard". I just got the forks today, so I shall start working on the project.
Initial fitment test:
The axle from the superhawk fits the forks perfectly, which is good. The wheel does not fit with both rotors installed, however it fits with a single rotor. I will need to make some axle spacers, as the stock ones do not fit correctly.
I also found that these forks have little tabs to hold the speedo sensor housing in place. These interfere with the wheel, so I will be grinding them off.
Once I grind the little tabs off I can mount the wheel and test if it will clear the front cylinder. Fingers are crossed. What I have to work with:
The bike:
The forks:
Still a ways to go:
Old Oct 31, 2009 | 03:46 PM
WAYNEHAMMER's Avatar
WAYNEHAMMER is on a distinguished road
why does the tank say suzuki? was someone confused?
Old Oct 31, 2009 | 03:58 PM
Little_Horse's Avatar
2nd mouse gets the cheese
I was thinking the same thing, lol.
Old Oct 31, 2009 | 04:18 PM
Just_Nick's Avatar
Who are you?
I was bored and put Suzuki stickers on the tank.
Old Oct 31, 2009 | 07:00 PM
Hmmmmm...ooooo k....
Old Oct 31, 2009 | 07:05 PM
Is that the same green as my old ZX12? (I miss that bike sniff sniff)
Old Oct 31, 2009 | 07:07 PM
Just_Nick's Avatar
Who are you?
Looks like it.
Old Oct 31, 2009 | 08:22 PM
You got a Honda in Kawi colors with Suzuki stickers?... Isn't that kinda like cross-dressing?
Get the poor thing rebuilt to a Motard... ASAP...
Old Oct 31, 2009 | 08:36 PM
Just_Nick's Avatar
Who are you?
On it!
Victory, front wheel mounted on forks:
Old Oct 31, 2009 | 11:09 PM
Blasphemy! ......
Old Nov 1, 2009 | 12:05 AM
supermarto's Avatar
Those tank stickers make my head explode...
Old Nov 1, 2009 | 01:33 AM
JIMMYJAMES's Avatar
JIMMYJAMES is on a distinguished road
I wondered if it was a TLS tank fitted for larger capacity, obviously not.
Old Nov 1, 2009 | 03:16 AM
ripvanwinkle's Avatar
aka sirch345. vtr1000.org
ripvanwinkle is on a distinguished road
Which make and model bike are the forks from?
Old Nov 1, 2009 | 06:14 AM
JamieDaugherty's Avatar
On it!
The front looks it like it's coming together for you - but what are you going to do about the rear? That seems like it would be a lot more difficult.
Old Nov 1, 2009 | 09:43 AM
Just_Nick's Avatar
Who are you?
I'm thinking about changing the length of the shock linkage so I get more wheel travel for the same amount of shock travel.
I might also throw in a dirt bike rear shock.
Old Nov 1, 2009 | 10:02 AM
NAVY8TR's Avatar
very interesting! i'm curious to see where this goes. good luck with the project
Old Nov 1, 2009 | 10:22 AM
dantropolis's Avatar
dantropolis is on a distinguished road
Dirt bike forks. Dirt bikes weigh like 250lbs or less right?
Single disk stopping SH weight?
I like that you're doing something different but everything about this concept is counter to what SuperMoto stands for. Frankenbike fits better.
Good luck.
Old Nov 1, 2009 | 10:43 AM
badboyrr's Avatar
"Oh geez"....that sticker!
Old Nov 1, 2009 | 11:20 AM
Just_Nick's Avatar
Who are you?
I didn't realize everyone would get so up-in-arms over a Suzuki sticker. Where's the humor guys?
Dan, I am going to be swapping to a F4i or RC51 caliper and master for stopping power. Since it's going to only have a single brake line, that should be more than enough stopping power. And also, I am going to buy some different springs if I don't like how the sag is. I am probably wanting it to be at 60% of its travel(so 7" of up-travel, 5" down-travel).
Old Nov 1, 2009 | 12:14 PM
doggerman's Avatar
doggerman is on a distinguished road
I got a chuckle out of it,saw you on barf also.Good luck
Old Nov 1, 2009 | 12:56 PM
Considering you are the one giving uchi so much flack I figure it's all in good fun. :P Plus you do have a crossdressing bike.. lol
Good luck on the swap! it is an interesting project.
Old Nov 1, 2009 | 01:13 PM
Just_Nick's Avatar
Who are you?
Haha I know, I just found it funny how people were so shocked by a sticker.
Old Nov 1, 2009 | 01:21 PM
A person's bike really does say a lot about them......
Old Nov 1, 2009 | 01:25 PM
Just_Nick's Avatar
Who are you?
Want some pictures? hahaha
Old Nov 1, 2009 | 01:29 PM
Ummmm....................................no. Thanks anyway.
Old Nov 1, 2009 | 01:36 PM
Just_Nick's Avatar
Who are you?
Okay guys I got some work done today.
First off, pulling the front fairing. Look, my own Suzuki streetfighter.
Next step, pulling the front wheel.
After that, off come the stock forks:
Damn these forks are way bigger. The lower triple is literally over double as thick:
And on go the WR250 forks:
Close-up:
Front view:
Finally, top triple installed:
Note that is all mocked up. I need to grind the steering stops down since they limit me to 10 degress of steering each way. I also need to drill the bearing cover wider so that no dust gets in there. And I need to make a spacer for it, as the steering stem is too long.
Old Nov 1, 2009 | 01:52 PM
Notice the position of the axle for both forks in relation to the centerline of the forks. Notice how the WR forks have the axle out front. That change in axle location will alter your trail numbers significantly. I don't know what year WR those forks are from. A quick search gave me a rake of 26.67° for the '08. The rake for the VTR is 24.5° and a trail of 3.8". When I did my 1000RR fork swap I was getting really funky handling characteristics by having the forks too far down in the triples by about 2cm. All I did was change the fork offset!
You really need to do some good R&D on this before you start bolting **** together and spending hundreds of dollars. Do a search for rake, trail, and offset and do some reading. Find an online trail calculator and figure out if this is going to work before you start.
Old Nov 1, 2009 | 02:05 PM
drew_c14's Avatar
For the love of god man, clean you garage! I'm having an OCD fit just looking at those pictures.
Old Nov 1, 2009 | 02:52 PM
Just_Nick's Avatar
Who are you?
You're more than welcome to come and help me clean it.
Old Nov 1, 2009 | 03:08 PM
steve.g's Avatar
Thats funny!! Guess its a Yamasakihonduki...
