Motor/Frame Locking Nuts Removal Tools
Old May 11, 2010 | 08:25 AM
FL02SupaHawk996's Avatar
Fastest Color
If you've ever tried to find the Honda tools specified in the manual:
07VMA-MBB0100
07VMA-MBB0200
Needed to remove the castle head locking nuts on the frame you probably didn't find them at Ron Ayers or anywhere else, so here's a link to an affordable solution:
http://www.craftsman.com/shc/s/p_101...2_00934299000P
I plan to get a set soon and I report back how well they worked...
Old May 11, 2010 | 09:30 AM
RCVTR's Avatar
I ordered mine from the local dealership. They weren't very expensive.
I don't think those Craftsman drivers will work, unless you can mill out the center section.
Old May 11, 2010 | 09:34 AM
Fastest Color
You may be right! I'll check with the local dealer too...
Old May 11, 2010 | 09:59 AM
Fastest Color
The Local Dealer had to research the part numbers cuz both have been superseded...he didn't give me the new numbers but the prices for the 2 parts are $105.25 & $128.99 each...
Old May 11, 2010 | 10:07 AM
RCVTR's Avatar
OUCH!!
Wanna borrow mine?
Old May 11, 2010 | 10:24 AM
Fastest Color
OUCH!!
Wanna borrow mine?
Actually, you should rent them out and watch the money roll in like a toll bridge
Old May 12, 2010 | 12:00 PM
Fastest Color
The craftsman slotted drivers wont work
looks like I'll be cutting down a couple of 12pt sockets so I may have to buy a plasma torch!
Old May 12, 2010 | 12:04 PM
Why?
I just used an angle grinder, some patience and a file... Took me 2-3 hours to make a complete set for all the castle nuts on the VTR, including the one for the steering stem...
It took me about 3 years however to get pissed off enough to start doing it... But that's an entirely different matter...
Old May 12, 2010 | 12:08 PM
Fastest Color
Why?
Why, cuz I don't have one yet
Old May 12, 2010 | 12:11 PM
Um... OK, that makes sense...
This is the one for the steering stem... No pictures of the others...
Attached Thumbnails Motor/Frame Locking Nuts Removal Tools-021-large-.jpg
Old May 12, 2010 | 12:14 PM
Fastest Color
That looks like a job my dentist did on me last week...LOL!
Old May 12, 2010 | 12:50 PM
Syclone's Avatar
Boosted
Why a special steering stem one? A 12 point 1 11/16" socket works perfectly.
Old May 12, 2010 | 12:55 PM
Fastest Color
+1, that's all I needed too, but I figured they musta put a castle nut on the Firestorms...
Old May 12, 2010 | 01:07 PM
Well on top of the top triple there is a normal one, yes... But underneath that you usually find a nut which is locked with a locking tab... A thin nut, a shim with tabs and a lower nut holding the stem to the headstock... And you can't use a normal socket as the steering stem is a bit to long for that... Now I'm fairly sure they used this setup on the Superhawks as well... At least they did in the pictures in the service manual...
And if you want to torque that to the specified torque when installing a taper bearing, a chisel is a bit imprecise...
Old May 12, 2010 | 01:10 PM
Fastest Color
Oh yeah, I remember that and I guess mine is imprecise
Old May 12, 2010 | 01:17 PM
Well... I had my taper bearing go crunchy after only two seasons, so I guess I had it either entirely to tight or too loose... So I swapped the bearings again and made that socket to get it right...
Like I said... Small amount of work, and it makes things a whole lot easier, without paying the ridiculous prices Honda wants for the "special" tools...
Old May 12, 2010 | 02:50 PM
Syclone's Avatar
Boosted
The VTR steering stem (or at least the 929 triple on mine) is short enough to torque properly with a 1 11/16" 12pt socket. My VTX, on the otherhand, is too long. I plan on dremeling out my socket so I can use it on the VTX too though. It's got just enough material to still use after dishing it out 1/2" or so.
Old May 12, 2010 | 03:48 PM
With an unusually long socket possibly... Mine wasn't long enough by far... But I just cut up one socket to get the bottom part and welded it to another one for the top part... Like I said, easy...
Old May 12, 2010 | 04:06 PM
residentg's Avatar
Servicehonda wants $76 for the first one (0100), but no listing for the second (0200). Castle nuts are common on gokarts, I may look to see if I can find one there. The first one is 20mm, do you know the spec for the second? Thank you. JB
Old May 12, 2010 | 06:18 PM
comedo's Avatar
The part no. on my "special tool" is 07HMA-MR70200. It's double headed so it can be used on two sizes of castle nuts. I checked the picture in the shop manual which shows the tool being used to remove the lock nut on the rearmost hanger bolt. The smaller diameter is the one being used. Its OD is 32 mm., its ID is 24 mm. and each of the 4 pegs on it is 6 mm. wide. The OD of the tool should match the OD of the lock nut. Please check before you buy.
Old May 12, 2010 | 06:48 PM
residentg's Avatar
Part Number.........Description.......................List Price....Your Price!
07VMA-MBB0100.....WRENCH LOCK NUT 20MM...$71.67.........$73.64
07HMA-MR70200.....LOCK NUT WRENCH............$101.1.........$83.10
This is from servicehonda.com
Old May 13, 2010 | 08:06 PM
fred's Avatar
Mid-level Member
fred
i didn't fare so well with that fork-slider nut, but hey. i'm really proud of my home-made streering stem socket. and that hard-to-find molybdenum disulfide grease... complements of you friendly neighborhood gunshop.
Attached Thumbnails Motor/Frame Locking Nuts Removal Tools-socket.jpg   Motor/Frame Locking Nuts Removal Tools-mds.jpg
Old May 17, 2010 | 08:24 AM
Fastest Color
Made my own caster nut/frame tools since paying over $70 each for them boarders on insanity!
Using a 4" grinder it was actually easy and took less than an hour to make both. For the 22mm I used an old 12-pt 7/8" socket and for the 20mm I used a 12-pt 3/4" socket.
Attached Thumbnails Motor/Frame Locking Nuts Removal Tools-20mm-caster-tool.jpg   Motor/Frame Locking Nuts Removal Tools-22mm-caster-tool2.jpg   Motor/Frame Locking Nuts Removal Tools-22mm-caster-tool3.jpg   Motor/Frame Locking Nuts Removal Tools-22mm-caster-tool.jpg
Old May 21, 2010 | 12:28 PM
residentg's Avatar
the tool that is used to remove the clutch nut on an XR200R fits the frame lock nut. I will look it up, I think I got mine from motion pro cheap.
Motionpro 20mm $9.23:
http://www.motionpro.com/motorcycle/partno/08-0385/
Honda 07716-0020100 combo 20mm / 24mm combo $30.62 at servicehonda
Old Jan 13, 2013 | 11:02 AM
Longmont's Avatar
Longmont is on a distinguished road
OUCH!!
Wanna borrow mine?
San Diego needs this tool - do you still have it?
07vma-mbb0100
Thanks -
Old Jan 13, 2013 | 08:55 PM
Wow, most informative thread in while. I borrowed the tools for my motor swap but will have to make or buy some eventually. Thanks guys.
Old Dec 3, 2014 | 08:38 PM
thedeatons's Avatar
https://www.superhawkforum.com/forum...43/#post380833
James
thedeatons
Jul 27, 2015 06:59 AM
bpw
Jan 20, 2015 06:12 PM
natewill
Aug 11, 2011 12:42 PM
Hardhead
Aug 8, 2008 10:56 PM
moto120
Apr 24, 2008 11:02 AM
