[ KB ] PAIR System Removal
Old Aug 11, 2004 | 07:23 AM
mamisano's Avatar
Super Moderator
mamisano is an unknown quantity at this point
Category: VTR1000F Modifications
Type: How-To
Article Name: PAIR System Removal
Author: mamisano
Description: How-To Remove The PAIR Emissions Equipment
>>Read Full Article
Old Dec 26, 2005 | 11:22 PM
Speed_Demon's Avatar
I can speak from experience when I say a malfunctioning pair valve will destroy exhaust valves and seats.
If your bike backfires under engine breaking or rev-down its probably a malfunctioning pair valve system.
If you can, disable it. If you can't, make sure the valve closes under vacuum and all the hoses are good.
Old Dec 27, 2005 | 07:18 AM
caffeineracer's Avatar
caffeineracer
How does a malfunctioning pair valve destroy an exhaust valve?
If the (oneway) reed valve broke, and it stayed open all the time, hot exhaust gas would just cook the air supply hose leading to the valve.
then it would give you an exhaust leak and lots of back firing.
Don't see why it would burn a valve though.
~Jeffers
Old Dec 27, 2005 | 10:50 AM
Thats not usually how they break. What usually happens is the vacuum line that closes the air supply valve under vacuum cracks and leaks and never closes off the air supply to the pair valve. I've never seen reed valve damage.
When air is allowed to enter under engine breaking it creates powerful backfires that pulverize the exhaust valves and seats.
Other than pounding and scortching the valves and seats, it also can build a carbon film on one side of the valve seat and over time the exhaust valve bends to match the irregular seat.
Fox
Feb 7, 2011 02:28 PM
andrewlc77
Oct 2, 2006 12:41 AM
SillyHawk
Sep 18, 2006 10:54 PM
EngineNoO9
Sep 11, 2006 07:23 PM
