Couple of high mileage shawk checks/preventative maintaince
Old May 15, 2005 | 01:17 PM
caffeineracer's Avatar
caffeineracer
Fairing edge can wear into lower radiator hose on both sides.
see picture,
Left radiator, lower flange, can wear into clutch line.
Stock rubber line protector had been worn though.
Picture shows piece of fuel line wrapped around stock protector.
~Jeffers @ 125,000 miles now.
Old May 15, 2005 | 03:41 PM
99Hawk's Avatar
99Hawk
Re: Couple of high mileage shawk checks/preventative maintai
WOW, That's a good wake up call to even us much lower mileage dudes to check hose and line runs now - and then grab the duct tape
Old May 15, 2005 | 09:29 PM
RymerC's Avatar
RymerC
good to know, thanks!. keep it going
Old Dec 28, 2005 | 06:23 PM
Speed_Demon's Avatar
125k on your VTR? Holy crap! I'm definately taking maintenance advice from you.
Old Dec 29, 2005 | 12:56 PM
AZZKIKER's Avatar
125k is a lot. What kinda major work have you done to the engine. Is it rebuilt, is it the same original engine??
Old Dec 29, 2005 | 01:28 PM
caffeineracer
Nothing really major.
Just the front carb diaphram and the regulator/rectifier.
Other stuff seems consumables or upgrades, like wheel and tappered steering bearings.
136.K miles now!
But I'm not putting miles on as fast lately as I bought another sport twin 2 months ago, it's an 05' SV1KS.
~Jeffers
Old Dec 29, 2005 | 02:20 PM
AZZKIKER's Avatar
wow, nice SV, how do you compare both bikes?
Old Dec 29, 2005 | 04:10 PM
caffeineracer
Should start a new thread as a comparo cuz I'm sure a few riders use these lists as information to help them choose between bikes.
There's a few things the shawk needed that the SV didn't.
I installed 320mm oversize rotors on the shawk,
The SV came with 310mm rotors that seem ample.
The SV's 46mm forks won't need a fork brace like I put on the shawk.
And I don't think I'll need to replace the SV's larger steering stem bearings with tappered ones that I put on the shawk.
The suspension on the SV is fully adjustable on both ends, rebound, compression, and preload.
And as the bikes come stock, the suspension is better on the SV.
But not nearly as good as a resprung, revalved, and reshocked shawk, like mine is.
The SV got resprung and a Penske shock, and now it's comparable, suspension wise, with my shawk.
~Jeffers
~Jeffers
Old Dec 30, 2005 | 06:10 AM
AZZKIKER's Avatar
Which bike is more FUN?
Old Dec 30, 2005 | 07:04 AM
jschmidt's Avatar
jschmidt
Highly valuable experience. Thanks.
Old Dec 30, 2005 | 07:10 AM
caffeineracer
That would be hard to say, I'm pretty infatuated with the new bike, but I've loved the shawk since I bought it new in 98'.
Seat of the pants dyno sez the shawk has a little more lowend that seems to have been enhanced with recent front velocity stack tuning.
(got a server 500 fault when I tried to upload the attachment)
That lowend grunt is a large part of the shawks appeal.
Midrange thru topend is stronger on the SV, and it has a nice snarl ripping up to it's 11.K redline.
That extra 1500 rpm on top allows you to charge further to the next corner without having to upshift.
Also the SV pulls hard all the way to redline, where the shawk seems to favor an upshift.
I was thinking of having a buddy meet me at home so I can take both bikes out for a proper test.
They're that close.
Actually my friend kai ju and I swapped bikes once, but the SV wasn't sorted yet at that time.
kai ju's streetfigher was a pretty bitchin' test ride!
~Jeffers
Old Dec 30, 2005 | 09:32 AM
AZZKIKER's Avatar
That's awesome info. Thanx
Tom Blum
Jul 18, 2008 04:44 AM
W-O-T
Jul 11, 2008 09:29 AM
joshn569
Feb 28, 2007 09:02 AM
motherbelgium
Aug 18, 2005 12:44 PM
bluesman
Jul 22, 2005 11:09 PM
