Warm up idle ?
Old Mar 5, 2012 | 09:55 PM
tomzxt's Avatar
Light Cycle Expert
Warm up idle ?
Before I go somewhere I let my SH get up to temp. I run it at idle, no choke, for about three minutes if I haven't used it in a few hours. After that it'll either cut out or the idle will drop to about 750RPM and I have to cut it off and back on again. Once I start it back up it runs fine. Is this just a weird quirk or something else? Thanks for any help.
A little extra info. Started happening after I changed the spark plugs. Temp is normal to cold when it happens.
Old Mar 6, 2012 | 05:13 PM
By the sound of it, it's not normal. VTRs (at least mine) is pretty slow to warm up. I have to let it idle for at least 15-20 min before the fan will kick on, but it will never die. Sounds to me like something happened when you changed the plugs. Ensure you have the right plugs installed (DPR9EIX9) and the plug wires are fully seated on the plugs. Check your tank hoses to make sure they are all installed correctly and that none get pinched when you reinstall the tank. That's about all I have to offer on this one. It's obviously related to the plug change since it didn't do this before the maintenance.
Old Mar 6, 2012 | 08:30 PM
The Superhawk is not a happy camper waking up - much less waking up cold. The more built she is the bitchier it gets. I can never keep mine on full choke for more than a few seconds. After that it cleans up a bit until the exhaust starts to run warm.
thedeatons
Jun 21, 2015 09:11 PM
zwoehr
Jul 25, 2010 08:53 PM
Mike996
Dec 22, 2009 08:29 PM
Stratman
Jul 1, 2006 02:24 AM
DaxMiddler
Apr 28, 2006 03:22 AM
