TPS Adjustment
Old Apr 28, 2010 | 07:22 PM
  #31
NAVY8TR's Avatar
Originally Posted by nath981
I never started it up to measure increase ohms. Just set the tps, measure 490-500ohms, then turn the throttle and watch ohm meter and ohms will increase(engine off).
alright. I'll give that a shot and see what I get. thanks nath
Old Apr 28, 2010 | 07:36 PM
  #32
NAVY8TR's Avatar
yeah no changes in resistance when I change the position of the throttle with the bike off. probably a good indicator that I didn't get the pin between the two tabs. damn
Old Apr 28, 2010 | 08:11 PM
  #33
alwayshonda's Avatar
alwayshonda is on a distinguished road
Yeah, you definitely got the pin under both of the tabs on accident. I'm not positive about the spring positioning as you mentioned. Mine went from 500 ohms to around 1500 ohms at WOT. I would think as long as you can get those readings, you should be good.
Old Apr 28, 2010 | 08:16 PM
  #34
nath981's Avatar
It's difficult to explain things when i never had my tps fly apart. I know this though and you might mess with it to see if you have it together correctly. If you stand on the left side of the bike with your carbs pulled up a little, you can look down at the tab as you put the bottom of the tps up against the carb and see that the tab is heading for the space between the two prongs. Then you hold the tps up against the carb and turn it counterclockwise and let the pressure off a little and it should spring back gently. then you know you have the tab between the prongs. Now turn it clockwise til you have the holes on the mounting plate centered in the oval slot on the tps. This is where mine was standard. or you might be able to see outline on the mounting plate of where yours was set OEM. Either way, when the hole is near the center of the TPS mounting slot and this should read about 800-900ohms. If it does, you know two things: you have it back together correctly and that if you move it counterclockwise it will read lower. Then you will probably need to bend the left tab a little to get it back far enough to 490 ohm. Hope you can understand what i'm trying to describe.
Old Apr 28, 2010 | 08:38 PM
  #35
+1 You could mark the TPS housing with some white out on the backside right where the tab is to keep its location in check. I put a lil dot and then lining it up with the two tabs was cake.
Old Mar 22, 2011 | 10:08 PM
  #36
nykuryu's Avatar
nykuryu is on a distinguished road
i just checked my tps and it came back ~871. is this right, can it even be that much out of spec?
Old Mar 23, 2011 | 04:28 AM
  #37
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
Yes, it is very common for them to be at that setting right from Honda. Once you get it set to 500 ohms, you will be surprised how much smoother it will run!
Old Mar 23, 2011 | 07:20 AM
  #38
I believe that I read somewhere that the TPS was spec'd at 500 by Honda, but for whatever emissions code they knowingly have the adjustment set high. Notice no one has the TPS below 500, or really even that close to it (so it's not just the factory being sloppy). I'd guess they designed it to be at 500, but then put it at 800 and stuck some tamper resistant heads on there to make some government happy.
Remember too, this mod only adjusts the smoothness of the ignition timing at idle- after you get into the rpm's you won't notice any real difference...
Old Mar 23, 2011 | 07:27 AM
  #39
SPRHK's Avatar
I was able to get my TPS EXACTLY 500 ohms, but had to elongate the screw slots a little. I have also done a few of these in my shop for customers, always been able to get anywhere from 480-510 depending on the unit.
Old Mar 23, 2011 | 07:48 AM
  #40
thetophatflash's Avatar
You'll notice a difference from idle to full advance.
Old Mar 23, 2011 | 09:03 AM
  #41
nykuryu's Avatar
how does the bike even run if the TPS is set that far out from factory?
Old Mar 23, 2011 | 09:08 AM
  #42
According to articles on the TPS this is correct... I hadn't had my bike fired up long enough to tell yet
Old Mar 23, 2011 | 09:27 AM
  #43
nykuryu's Avatar
it better do more then idle timing. my idle is freakin perfect. its my cruising that sucks donkey *****.
Old Mar 23, 2011 | 09:48 AM
  #44
SPRHK's Avatar
It should smoothe her right out. Did it for mine.
Old Mar 23, 2011 | 09:53 AM
  #45
nykuryu's Avatar
and to be clear, im just touching the top and middle pins of the tps with my multi- meter leads? i have the meter set at 2000 ohms since the next lowest is 200
Old Mar 23, 2011 | 12:51 PM
  #46
jay956's Avatar
ever since i did this the bike starts MUCH easier
Old Mar 23, 2011 | 01:45 PM
  #47
nykuryu's Avatar
my post above your last, is that how you checked your tps?
Old Mar 23, 2011 | 01:52 PM
  #48
What Honda does is run the engine on a dyno and sets the TPS using an emission sensor in the exhaust. They set it to the lowest emission at idle. That is why they are all set a little different and also the reason for tamper resistant fasteners.
So 500 ohms is the spec for power. I have heard of one person claiming 430ohms was a better set up, but I don't have any (or seen any) numbers to back the claim up.
Old Mar 23, 2011 | 05:59 PM
  #49
jay956's Avatar
i believe so, but its been a while. your not gonna get a reading if you touch the wrong ones...
Dave Wicks
May 6, 2009 08:07 AM
EngineNoO9
Sep 26, 2006 06:34 AM
99Hawkboy
May 17, 2006 07:24 AM
CNI Dawg
Forum Feedback
May 16, 2006 03:59 PM
troy_v
Mar 25, 2005 08:48 PM
