special tires for the hawk!
Old Apr 30, 2009 | 05:54 PM
  #31
Hotbrakes's Avatar
Originally Posted by Red_Liner740
uh oh....i just put on BT014's to replace my BT015's which arent so much done as they took chemical abuses, and are starting to weather crack...
hopefully i get more than 2500 miles out of my rear....in which case i'm going with a BT016 rear...
Try some tire shine to restore a weathered tire...
In response to rear tire pressure, running max with a lighter load will increase the tire wear because the tire will not be conforming to the road as well causing it to slip slightly which will scrub off rubber. Plus less of the tire will be contacting the ground causing increased wear to a smaller area of the tire. Finding the happy medium where it flexes enough to provide traction and heats up to get sticky should yield the best results. I think the tires are designed for optimum performance and wear at 42psi, so the cold pressure should be less than that to achieve 42 once heated up. More weight will cause more heat and expansion/pressure, so the cold pressure should be increased to reduce the extra flex from added weight so the tire maintains 42psi. I know on the track 35psi hot is good for traction. So starting out around 28psi cold should get it to around 35psi hot depending on conditions, speeds, and ambient temp. And not wringing it out light to light will also prolong the life.
Old Apr 30, 2009 | 05:59 PM
  #32
HRCVTR1000's Avatar
I was getting tired of replacing the rear every 4000 miles or so also . I put a Pilot Road 2 on about 600 miles ago ...so far it seems to be a pretty good tire ! I have ridden the mountains a few times got em scrubbed all the way to edge . They seem to stick pretty well so far . I actually rode The Dragon in the rain ( at a reduced pace) , wet traction was amazing ! Plus there is a guy on another forum who has managed to get over 11k documented out of a rear . See here ......http://www.twtex.com/forums/showthre...t=31232&page=2 I would be happy to get half that .
Old Apr 30, 2009 | 06:02 PM
  #33
nath981's Avatar
I stopped buying expensive rear tires for my street ride.
I started using dunlop qualifier 190/55 (160 bucks retail) on rear and guess what?
Once you get them scrubbed in good,( no chikken strips ) they actually stick to the ground good.
I keep my Metzeller M3s on front and the combo works great.
Many times I drag my pegs thru turns, and that cheap *** dunlop has never scared me.
I would venture out to Henderson or somewhere on track day with this tire.
We know of course it wont hang with the M3s I usually ran on that wheel, but it outlasts one by 3x.
It has a harder center than the sideawalls, so Im getting almost 10,000 miles out of one.
This BTO-16 I bought was 160 includ shipp, so it's in the same price range. I was looking at April's Sport Rider magazine at Mikster's behest. They tested sport tires includ the dun Qualifier. They rated the Dunlop similar to the Bridgestone. The thing I was surprised to see though was that it weighs 1-3lbs more than the others tested. Maybe that why the phenonemal mileage, huh? But to concur with your experiences, it was rated at the top along with the Michelin for traction. The M3 didn't do as well traction wise and overall. That said, they're not gods at SR, but their tire eval is a better oppotunity in terms of testing than most of us will ever have.
Scraping pegs: I took mine loose and rotated them back 1" and up 1 1/2", then cut little metal strips to hold them there; and jacked the *** end 6mm.
Old Apr 30, 2009 | 09:01 PM
  #34
johnclopp85's Avatar
johnclopp85 is on a distinguished road
I just started riding street. Bought my SH about 2 weeks ago. I never put much thought into psi/weight ratio. So I'll ask you guys I weight around 225 (6'4"). What psi would you recommend for the front and rear tire. Thanks
Old May 1, 2009 | 04:36 AM
  #35
nath981's Avatar
This is a subject that no one will likely be willing or able to answer definitively. Most just err on the side of caution and say run what it tells you is the max pressure for the bike/tire.
I would tell you my way. Find a favorite most curvy road(s) and practice riding it with full pressure. when you get good on that road and feel comfortable leaning to the edge of the tires, then drop the pressure 5-8lbs and make some runs on a couple different days. See if you can feel traction differences.
Notes:
Look at your tire sidewall and you'll find the weight load rating(58W= 520 load carrying capacity per tire--Sport Rider,april 09).
know that heat raises tire pressure, so in hot weather/road surface, the pressure will increase. know also that aggressive riding increases temperature further. The reverse occurs for cold weather/surfaces.
warmer tires grip better, cold tires slide easily!
if you favor most mileage over most traction, run max pressure.
when you load bike with rider/cargo, and when you're going to travel primarily straight roads, use max pressure, because it's a waste of your tire middle tread to run lowered pressures in these instances where stopping, leaning and accelerating hard are minimized.
Most important: If you're new to the streets get yourself into a MSF course, do track days, and get an experienced rider to teach you how many ways that street riding is the most lethal form of the sport bar none.
Old May 1, 2009 | 05:07 AM
  #36
JamieDaugherty's Avatar
Notes:
Well said Nathan. The only part that I would take exception to is your comments about trade-offs between pressure and traction. On the street, a tire at the rated pressure will still provide great traction - that's not an issue at all. It's more about heat in the tire and wear. The bottom line, if it says 42psi on the side of the tire then you should run 42psi. The only exceptions are track days or extremely hard street riding.
Old May 3, 2009 | 01:45 PM
  #37
nath981's Avatar
thank you/
I thought this was interesting:
CW mag evaled michelin's new power one racing tires and put a write-up in the June issue. You can go on the website below and put in your bike info and they'll tell you the best choice and recommended air pressures in bars(you need to convert to psi). This won't include diff size rear wheels/tires, so you may have to change bike selection that has same size rubber as yours. Their pressure recommendations will surprise many in terms of how low they are(28 to 30psi).
Of course, there is the typical disclaimer advisory to follow the bike manufacturers air pressure recommendations so that there can be no legal repercussions based on their recommendations. And, these are race tires made to different specs, but the implications are that lower pressures for track or track like riding provide better performance. I've been running lower pressures for several years now and for the kind of riding I do, it works well(most twisty-few straight-one up-100-150mi-aggressive lean). The 2500 miles wear I got on the BTO-14 rear is an anomaly for me(usually 4-5 thous)and is not uncommon for these Bridgestones according to others who have reported similar experiences with them(the rears).
www.michelinpowerone.com
Old May 3, 2009 | 05:00 PM
  #38
thank you/
It says pretty clearly on there "For track use". Track pressures are always in the 30-32psi range. For the street you should be running 40-42psi or whatever it says on the side of your tire.
Old May 3, 2009 | 07:36 PM
  #39
nath981's Avatar
[QUOTE=JamieDaugherty;214517]It says pretty clearly on there "For track use". Track pressures are always in the 30-32psi range. For the street you should be running 40-42psi or whatever it says on the side of your tire.
AH OH! I guess I don't follow directions very well. "Street use" is a broad category with a multiplicity of variables, many of which don't apply to some of us, other than they happen to be on the street. I have found that lower pressure with my weight and type of riding has benefits similar to those who run lower pressure on the track, and I would think that many experienced street riders that regularly run the twisties do the same.
Old May 4, 2009 | 04:15 AM
  #40
[QUOTE=nath981;214545]
If you run higher pressures you don't really lose much traction (on the street, mind you). The rear spins a little easier when cold, but after a few miles of heat I challenge anyone to tell the difference. The treadwear is much, much better when running the suggested pressure.
If I rode some knee dragging canyon road every day to work I'd run the lower pressures, but since I live in Indiana that just doesn't apply!
Old May 4, 2009 | 07:39 AM
  #41
nath981's Avatar
[QUOTE=JamieDaugherty;214576]
If you run higher pressures you don't really lose much traction (on the street, mind you). The rear spins a little easier when cold, but after a few miles of A I challenge anyone to tell the difference. The treadwear is much, much better when running the suggested A.
If I rode some knee dragging canyon A every day to work I'd run the lower pressures, but since I A in Indiana that just doesn't apply!
that's my point exactly. i do prefer what i call bending turns and low tire pressure is an important part of this equation. I would accept that challenge because I've been riding the same curvy roads(within 100 miles of my house) for longer than i care to recount(40+, shhh, don't tell anyone) and i would not do it the way i do with max aired tires. No way, the differences in feedback/feel/traction/compliance/absorbtion are obvious and apparent. It's like you said, "if i rode some knee dragging canyon....................lower pressures"
If i lived in an area without close access to serpentine roads, i probably wouldn't even own a street-only bike. I'd be happy thrashing a dual sport ride around to get to some dirt trails.
Old May 4, 2009 | 03:46 PM
  #42
Hotbrakes's Avatar
If you are at max load. If not...less pressure. Tires are designed to flex and conform to a certain degree. Running max pressure at less than max load doesn't allow this so traction and the contact patch are reduced. Who cares what psi or how good your tires are if you slide your bike into a ditch? Granted it probably doesn't make that big a difference, but I want every advantage possible when it comes to control and safety.
Old May 5, 2009 | 05:01 AM
  #43
Erik S.'s Avatar
Correct me if I'm wrong, isn't that the "MAX PSI" for the tire on the side wall?
For car tires, I wouldn't run a Load Range E 16" tire at full pressure on my 3200 pound Cherokee, even though that's what the sidewall says. It would be like riding in a Sherman tank.
What does the owners manual call for? That's where your tires should be. Those test track riders get paid good money, and the engineers get paid good money, to try to figure this out before we get our bikes.
Old May 5, 2009 | 05:10 AM
  #44
Erik S.'s Avatar
To answer my own question, the Service manual calls out 36 front and 42 rear, both are COLD tire pressures.
Old May 5, 2009 | 11:13 PM
  #45
Infusi0n's Avatar
Infusi0n
I run 38 front 42 rear cold tire pressure and i have never had any problems at this temp, on the track i tend to lower to about 36/36 or 36/38. Again I have never had a problem riding with these pressures.
Old May 5, 2009 | 11:37 PM
  #46
Truckinduc's Avatar
hmm, With everyones good reviews, Im starting to wonder about the Conti Attacks.
My buddie put a set on his Ducati 750 monster, and the rear was showing cord after 1800 miles. He was not riding hard.
Old May 6, 2009 | 03:49 AM
  #47
That's because you are running the pressures that you are supposed to be running!
Old May 6, 2009 | 03:17 PM
  #48
Hotbrakes's Avatar
No slips at all? That's very high for the track. Last year I was running 30 in the rear of the RC and it was slipping. Hot it was 36-38psi. Lowered it a little more to 35 hot and it was sticking great. Everyone I've ever talked to runs around 30psi front and rear at the track.
Old Jun 15, 2009 | 01:44 AM
  #49
superskinner's Avatar
superskinner is on a distinguished road
+1 for Michelin Pilot Road 2CT front and back. Excellent ride, traction, and wearability
Old Jun 15, 2009 | 04:33 PM
  #50
cameron's Avatar
it didnt take me long to realize that a sticky race tire isnt going to make it much past a oil change. i just took the plunge and got a shinko raven sport touring tire. after 100 miles not so much as a almost slip out of it. i took this tire and pushed harder than normal on all my usuall curves. the turn in isnt as quick but you cant beat a set of tires for 150 bucks. if i get the reported 8,000 miles out of this elcheepo im hooked.
Old Jun 15, 2009 | 07:56 PM
  #51
nath981's Avatar
yeah, it will be interesting to see how you make out with these. It's amazing how expensive motorcycle tires are.
Northman69
Mar 17, 2013 06:27 AM
superhawk4cc
May 3, 2010 09:09 PM
reaper
Aug 23, 2007 08:42 PM
Carbo-Chicken
Jul 12, 2006 12:11 AM
sprhawk neil
May 22, 2006 08:50 PM
