SH Newbie Problems
Old Jun 24, 2011 | 07:08 PM
Acidbraker's Avatar
Acidbraker is on a distinguished road
SH Newbie Problems
It's me, the noob. Just picked up the Hawk today. Battery was week after sitting. Rode it for a while then got off for a few minutes to chat with my GF's folks. Let it idle, afraid it wouldn't fire if I turned it off. Two things happened.
#1 Bike overheated. Coolant out the overflow onto the ground.
#2 Cooling fan did not turn on.
Questions: (because I could not download the manual) How do I know when I've added enough coolant to replace what was lost?
Is there a light that would come on if the coolant level was too low to safely ride?
The yellowish "S" light is for the sidestand, right?
I only have about twenty minutes of ride time on her so far. I know that I should not have left it idling.
I think I can deal with the fan issue fairly simply.
Thanks
SH rookie
Old Jun 24, 2011 | 07:14 PM
K30's Avatar
K30
K30 is on a distinguished road
#1 Are you sure it overheated or was the coolant tank too full?
#2 Bust out the multimeter
Yellow S light is the sidestand.
There are two lines on the coolant reserve tank, UPPER and LOWER. Fill until the coolant is in between them.
Old Jun 24, 2011 | 07:16 PM
Acidbraker's Avatar
She was for sure overheated. Red-zone on the gauge, lots of bubbling in the reservoir.
Old Jun 24, 2011 | 07:19 PM
Check out the second post here, this is how I'd start:
https://www.superhawkforum.com/forum...n-noise-25966/
Old Jun 24, 2011 | 07:45 PM
Acidbraker's Avatar
Awesome, thanks for the diagram. I really don't think the pump or thermostat is broken. I just had it sitting there for too long at idle, no wind, hot humid day. The sensor very well might be broken, in which case I'm just gonna throw a toggle in the loop.
Is there any way someone could e-mail me the manual. I just can't seem to download it. I think it might be the security settings on my work computer.
My e-mail is ..................removed.
It might even get me to stop asking stupid questions.
Thanks folks,
-wide-eyed noob
Old Jun 24, 2011 | 07:52 PM
K30's Avatar
K30
At 140MB, it is too big to email.
You should be able to browse it through this site, it'll take a while to load though.
http://www.scribd.com/doc/32880387/H...l-ENG-by-Mosue
Old Jun 24, 2011 | 08:00 PM
Acidbraker's Avatar
Nice, that works. Thank you!
Old Jun 24, 2011 | 08:05 PM
Acidbraker's Avatar
Oh, and by the way, HOLY ****! This freaking bike is touchy! Super loud too! Absolutely in love with it. Hope it never ends!
Old Jun 24, 2011 | 08:10 PM
oahu hawk's Avatar
geezer
You stated the fan wasn't working, that'll do it...
Old Jun 24, 2011 | 08:33 PM
Acidbraker's Avatar
Yep, that's what I figure too. It's not too hard to loop in a manual toggle into the fan circuit, is it?
Old Jun 24, 2011 | 09:42 PM
racer187x's Avatar
racer187x is on a distinguished road
I'm new to the superhawk too. A few hundred miles since I bought it. Today I replaced the radiator fluid as I wasn't liking how warm it was getting during the day and its only getting warmer here in L.A. The old stuff was dirty! Definitely needed replacing, was probably the original coolant in the thing.
I've used the Honda premixed anti-freeze in pretty much all my bikes, not that expensive and ready to dump into the cooling system. May be worth it to flush your system with some new anti-freeze as you never know how long its been when you buy used.
Old Jun 24, 2011 | 10:00 PM
Acidbraker's Avatar
My fluid was new last summer. Bike wasn't used much for the past two years. I know the guy I bought it from really well. Everything is pretty much perfect except for the fan. I'm hoping to get that fixed tomorrow. I wanna ride! Today was the first nice day in about two weeks here in the frigid north.
-Cheers!
Old Jun 24, 2011 | 10:17 PM
Check to make sure it spins freely and that the fuse isn't blown.
Old Jun 24, 2011 | 10:30 PM
Kendrick's Avatar
The Hypno-Toad
Second...when my fan "failed" I spun it and it started working again. It just stuck for unknown reasons and has been fine since.
Edit: Unless you're in Canada I equal your frigid north and the hawk will always overheat if at a stop too long under any conditions with that fan not working. It should really never go over half way on the gauge. Just offering what I know...
Old Jun 24, 2011 | 10:35 PM
Acidbraker's Avatar
I will try that tonight when I leave work. Mine is the '99 model. About where on the gauge will the fan kick on?
Old Jun 24, 2011 | 10:38 PM
Kendrick's Avatar
The Hypno-Toad
Smile
On my 98 close to half way. For that matter it's been the same on all my Hondas. If it's below 90F and you're above half way your fan is acting up.
Old Jun 24, 2011 | 10:46 PM
Acidbraker's Avatar
Cool, thanks! I'll let you all know what I come up with And now, I'm off work for the weekend!
Cheers~!
Old Jun 24, 2011 | 11:28 PM
Disabling failsafe's is not always the best idea. If it's just the fan, pretty easy to diagnose. Just pull the wire coming from the temp sensor and touch it to the metal of the rad when the bike is on... if the fan turns, on, you have a faulty sensor. If it doesn't there's something wrong with the wiring. +1 to checking the fuse first though, haha!
Old Jun 30, 2011 | 09:52 PM
Acidbraker's Avatar
Figured out the fan problem. One of the supports of the plastic "housing" around the fan is cracked causing torsional pressure against the fan. I'll have to take off the fairing one of these days and see if I can jerry-rig it.
xecutech
Feb 4, 2025 11:39 AM
Jpkore
Apr 25, 2007 06:55 PM
Surflop
Mar 7, 2007 09:58 AM
sandygirly
Jan 29, 2007 06:47 PM
WildFire
Jan 24, 2007 10:36 AM
