runs like a sack of shit
Old Sep 4, 2009 | 10:42 AM
evil-kev's Avatar
evil-kev
Angry runs like a sack of ****
Hay people,
Any help would be much appreciated; right I have a 98 firestorm that was left in friend’s garden for three months in crap wet British weather. The problems that I am having is, it will start first time and idles ok, I will ride for 2 miles then it will stall, it starts ok but with no power massive flat spot or it will ride with flat spots in the rev range but gets worse then keeps stalling with no power at all,
I have cleaned and drained the tank (bit of water and rust). Card cleaner and new fuel added.
Spark plugs checked all ok
New battery
All fuel pipes checked
New filters
New oil.
Stripped carbs cleaned and sprayed
Please any help.
Old Sep 4, 2009 | 10:52 AM
jbaxx's Avatar
Honducati
Make sure the fuel tank is venting properly. Check the hoses for clogging.
Old Sep 4, 2009 | 11:21 AM
Zedicus's Avatar
Zedicus is on a distinguished road
the vaccuum tube goes to the back of the petcock, not the bottom. double check it, its same as what mine did.
Old Sep 4, 2009 | 03:19 PM
LineArrayNut's Avatar
I could ride in
PVLIR ^ what he said
Old Sep 4, 2009 | 04:50 PM
lynchie's Avatar
AZ RIDER
sound like gummed up fuel line for sure, i have had similar symptoms with other bikes that sat for a long time, i had to get some carb cleaner and take carbs apart for a cleaning
Old Sep 4, 2009 | 06:03 PM
chickenstrip's Avatar
chickenstrip
Regarding the clogged vent tube possibility, when it stalls next time try opening the gas cap to let air in the tank. If it starts and runs then you've got a good indication that venting is the culprit.
Old Sep 5, 2009 | 02:22 AM
gboezio's Avatar
I'm pretty sure that the carbs bowls get empty, there's got to be a problem with the petcock, check the hose that goes to the back of the petcock, should be routed to the rear cylinder head, pull the tank and make vacuum with a syringe, the gas should flow when the vac is applied.
Old Sep 5, 2009 | 12:53 PM
evil-kev's Avatar
evil-kev
Hi checked the pedcock and fuel flow is fine from both ports hose is line, vacume hose had a bit of a kink in it replaced hose, pulled the carbs again fuel in front but not back, does anyone no what the two pipes that go direct ontothe tank do, big one little one ???
thanks for the info so far still happening .
Old Sep 5, 2009 | 01:24 PM
drew_c14's Avatar
Sounds exactly like PVLIR, just my .02 cents... I can post a pic if you need.
Old Sep 5, 2009 | 03:45 PM
evil-kev's Avatar
evil-kev
Question
Sorry what does pvlir mean
Old Sep 5, 2009 | 05:00 PM
drew_c14's Avatar
the petcock should be hooked up like this, not with the tube on the bottom
Old Sep 5, 2009 | 07:52 PM
jbaxx's Avatar
Honducati
Pretty sure it's: Petcock Vaccum Line Inadvertent Relocation.
(Means the hose is hooked up wrong).
Old Sep 6, 2009 | 01:04 PM
evil-kev's Avatar
evil-kev
Just went for a ride and still happening, petcock all ok all connected ok , rides all ok for about 10 min then thats it back fire, flats spots, loss of power, doesnt stall, lossing the will with this, any more advice.
Old Sep 6, 2009 | 02:07 PM
evil-kev's Avatar
evil-kev
Just removed the petcock after the last ride and when removing i got some presure release, went out for another ride with the second key, when the stalling began to happen i opened the filler cap and seemed to be fine again, put filler back and again after about 10 min the stalling and spluttering started to begin again, now i have two pipes connected to tank, a big one that i can blow through both ways, a smaller one that has a plastic connecting bit in middle can blow one way but cant blow into the tank is this correct, ???????
Old Sep 6, 2009 | 03:16 PM
pull up an online parts fiche so you can see how this all fits together. Once you get it down you will never **** it up again.
Old Sep 6, 2009 | 06:34 PM
jbaxx's Avatar
Honducati
The fuel tank is not venting. One hose is the vent and the other is the overflow. If you can't blow to the tank on the vent tube- well, there's your problem.
Is the plastic piece in the tube a one- way valve? Maybe it's installed facing the wrong direction? Don't have my manual handy, maybe someone knows or can check.
You're almost there.
Old Sep 7, 2009 | 01:19 AM
evil-kev's Avatar
evil-kev
Smile
******* love you guys. Thanks sorted
Old Sep 7, 2009 | 07:50 AM
cameron's Avatar
well im very impressed with the way you superhawk riders handled this guys problem. you guys deserve a round of applause. Good JOB!
Old Sep 7, 2009 | 08:54 AM
jbaxx's Avatar
Honducati
So, what exactly did you find kev?
Old Sep 7, 2009 | 12:23 PM
evil-kev's Avatar
evil-kev
Maybe not sorted, The problem Is tank not venting blocked vent, that's all very good but I can't unblock the tube that runns through the tank, I have tryed wire wd40 air presure but no joy I can't get any air flow through the pipe, any help please you lot have been wicked so far,
Old Sep 7, 2009 | 01:09 PM
jbaxx's Avatar
Honducati
Are you saying that the tank itself has a blockage?
Old Sep 7, 2009 | 01:54 PM
drew_c14's Avatar
hhhmmm....
Have you recently painted the tank? I've seen that done before. Try and think back to what preceded this problem. You said friends garden for three months, did a critter get into the line maybe?
Old Sep 7, 2009 | 02:03 PM
Try going at it from the opposite end... Plug the compressor to the outlet and blow the blocking out the way it came in... Just make sure to empty the tank and clean it out afterwards... Definetly no water though...
Old Sep 7, 2009 | 02:58 PM
evil-kev's Avatar
evil-kev
Tryed blowing air both ways but no joy. What ever is in there is stuck there, the vent pipe seems to be teed into the over flow pipe in the tank, two options I think, new tank, drill a hole in top of tank to let it breath.
Old Mar 26, 2013 | 11:26 PM
whatthefnck's Avatar
THE LANE CARVER
Ahhh so the small grey hose goes in the back? And that one pointing downward should be left open to vent? Think that was my problem after reinstalling fuel tank...
Old Mar 27, 2013 | 05:57 AM
See your other thread running for a picture.. But yes, bottom is a vent, back is the vac port for the line.
Old Mar 27, 2013 | 07:50 AM
I would recommend against drilling your tank. You will regret it and it can only lead to great unhappiness.
SPEED DEMON1322
Mar 11, 2013 04:45 AM
Tebs
Oct 4, 2012 12:09 PM
blamecanada
Apr 16, 2012 09:34 AM
Superbroke
Aug 9, 2011 01:11 PM
EngineNoO9
Jan 19, 2007 04:14 PM
