REPLACING CAM CHAINS & TENSIONER HELP?
Old Jul 20, 2014 | 01:40 PM
XKyleX's Avatar
XKyleX is on a distinguished road
RECENTLY PURCHASED A 2000 VTR1000 WITH 37K . I AM HEARING THE DREADED CAM CHAIN NOISE .
I AM JUST WONDERING IF I SHOULD REPLACE THE CHAINS ALONG WITH THE TENSIONERS , OR IF MOST PEOPLE ONLY DO JUST THE TENSIONERS AND LEAVE THE CHAINS ALONE .
THANK YOU
Old Jul 20, 2014 | 02:15 PM
CrankenFine's Avatar
Most people only change tensioners but that is presuming there is no valve, cylinder head, nor piston damage. If you were unfortunate and already had a valve hit a piston, it may be well worth replacing the timing chain for that cylinder. Good luck, hope it works out well.
Old Jul 20, 2014 | 03:39 PM
Yes, if you have damage, it will be to the valves and maybe piston head. Chains are usually fine as they don't really bear the brunt of the stress. What kind of noises are you hearing (absolutely don't start it again if there were noises)
Old Jul 20, 2014 | 04:12 PM
+1 on just the tensioners.
And BTW, ALL CAPS IS THE EQUIVALENT OF SHOUTING AT US!!!!!
Old Jul 20, 2014 | 06:40 PM
jerryh's Avatar
I think in this situation caps is a cry for help. Hate to hear about this again, bummer!
dustinwild
Sep 4, 2025 12:04 PM
ashmash69
Aug 17, 2015 02:02 PM
K30
May 22, 2011 01:51 PM
L8RGYZ
Sep 26, 2006 07:13 AM
Racer647
Aug 21, 2006 10:22 PM
