Rear stands
Old Sep 29, 2010 | 06:57 AM
deiss44's Avatar
racer44
deiss44 is on a distinguished road
Rear stands
I am making a couple rear stands. I will post a pic tonight. If anyone is interested I will sell a couple next week. I am experimenting with an axle mount and a axle nut mount. It will probably be around 70.00 shipped.
Old Sep 29, 2010 | 07:11 AM
RWhisen's Avatar
Former Superchicken Owner
If you have your bike resting on the axle and axle nut, how are you going to loosen or tighten it?
Old Sep 29, 2010 | 10:14 AM
deiss44's Avatar
racer44
After playing with it, I soon decided to have a swing arm mount. I bought some pegs to drill in but I am going to make the stands so no peg is needed. Its almost done. It is going to be adjustable in and out and should work for many bikes. Thanks
Old Sep 29, 2010 | 10:50 AM
justinity's Avatar
Über Member
Waiting for pics..
(interested)
Old Sep 29, 2010 | 12:25 PM
Old Yeller's Avatar
Harbor Freight 40 bucks:
http://www.harborfreight.com/motorcy...rce=googlebase
Old Sep 29, 2010 | 12:54 PM
RWhisen's Avatar
I use those Harbor Freight ones and I'll tell you they are freaking scary on the front! Works great on the back. Are steering head attachments any more stable?
Old Sep 29, 2010 | 12:58 PM
98VTRrider's Avatar
I've been thinking of doing the same..interested to see how yours turn out.
Old Sep 29, 2010 | 02:33 PM
I've built about 4 now for the VTR.. I kept one, one went to Nuhawk the others i shipped to folks on another list. . $5 in steel, $2 in wheels, $2 in fasteners, $4 in paint, piece of used mountain bike tire and an old handle bar grip.
Old Sep 29, 2010 | 02:45 PM
Show us some pics Love to see what other folks are building
Old Sep 29, 2010 | 02:48 PM
justinity's Avatar
Über Member
Well not entirely but you know
Old Sep 29, 2010 | 05:09 PM
Attached Thumbnails Rear stands-small%2520stand.jpg   Rear stands-rear%2520stand.jpg   Rear stands-new%2520stand%25201.jpg
Old Sep 29, 2010 | 05:20 PM
justinity's Avatar
Über Member
Thank you,
That looks pretty easy to make.
Old Sep 29, 2010 | 06:07 PM
deiss44's Avatar
racer44
Good luck with those harbor frieght jobs. I got finished with one but could not take it home to take a pic given I ride to work every day. Some posted pics of theirs. This looks much the same except there are no welds on the angles given i used a tube bender. The bend is 105 degrees allowing the stand to be very stable due to the backward force. I will try to get them up tomorrow.
Old Sep 29, 2010 | 06:12 PM
RWhisen's Avatar
Good luck with those harbor frieght jobs.....
I didn't say I liked them, just said that they were cheap. I don't like using them on the front but they are stable on the back. The only thing I would recommend is a double wheel setup instead of a single.
Old Sep 29, 2010 | 07:04 PM
Yeah, and it's truly flawless. Especially when the bike is in the vise on the lift. Chain maintenance is a breeze.
Cheap alterrnative even if you're a renter - strongback in the garage ceiling with eyebolts above your work area. I tore apart the Superhawk and the Interceptor by hanging the bike from the ceiling and using jacks.
Old Sep 30, 2010 | 05:40 AM
deiss44's Avatar
racer44
I am working of a front as well. And your right, I have used many fronts and I agree, very unstable and scary to use, especially by yourself.
Old Sep 30, 2010 | 06:28 AM
redmanmbz's Avatar
redmanmbz is on a distinguished road
Looks simple enough to build one yourself, just need a welder (or friend with one). Thanks for the pics.
Old Sep 30, 2010 | 06:49 AM
wshski's Avatar
wshski is on a distinguished road
1 pic shows stand with 45 deg. braces, other 2 has none. I think the braces would ease peace of mind !!!!!
Old Sep 30, 2010 | 08:24 AM
My take on it... https://www.superhawkforum.com/forum...11&postcount=1
Makes a front stand completely redundant and it's easy to use on your own...
http://www.werner-staender.de/wernerMQ.wmv
Old Sep 30, 2010 | 12:32 PM
The one without the braces is one I made for my bike.. been in use 5 years,,,,, no issues.
I added braces to the other ones cuz I was asked to by the buyers.. It does not need them, but was an extra 5 min to add um,, so I did.
Old Sep 30, 2010 | 01:08 PM
RWhisen's Avatar
That works great Tweety. Did you make the little fork support as well?
Old Sep 30, 2010 | 02:04 PM
Old Yeller's Avatar
Tweet's idea is a good one to work on the bike, but for track purposes or quick needs, the other options are better. My only issue with deiss44's original post is that 70 bucks is pricy when I can get 2 at HF for that much considering how they've been advertising discount coupons in MC rags these days. With a 20% off coupon, that puts the price at $32 plus tax.
Old Sep 30, 2010 | 02:14 PM
RWhisen's Avatar
I'm going to make one of these with some flanged studs to automatically set the proper alignment when inserted.
You can't beat 32 bux....
Old Oct 1, 2010 | 06:39 AM
deiss44's Avatar
racer44
I posted the first post not knowing how much it would be to make one of these things and how long it would take me. As most of you said $70.00 is too high for sure. But who can beat 32 bucks after you pay for the material and your time. I have yet to post pics but will this weekend. I made a rear that takes after flattrack stands and a front that resembles road race stands. They both work great. If anyone wants one, front or rear after the pics are posted, just let me know. They will not be as cheap as harbor freight, but maybe 75.00 for the set or 40 each. When I post the pics let me know what you all think.
I really like the center stand idea but I can't figure out where a good mounting spot would be. If anyone has any ideas I can try it. I have a weld/machine shop at my disposal so anything is possible.
Old Oct 1, 2010 | 06:44 AM
Nah, I just use a wood block under the oilsump instead... Then I can take of the forks...
Actually... The way I did it, using a 17 mm socket on one side, and a "spike" on the other, and then adjusted them and drilled holes for a locking clip, you don't need to adjust them... Just stick the one in, lock it, put tension on it and lock the other...
I made an pdf with the measurements, I translated the text to english for you... BTW since it confused some Swedish VTR owners, the stand is "backwards" in the image... The "handle" will be on the same side as the kickstand, pointing at the front wheel... That way it's rock stable, and easy to use...
File Type: pdf
Old Oct 1, 2010 | 06:52 AM
RWhisen's Avatar
It is an excellent idea. How long did you make the uprights?
Old Oct 1, 2010 | 06:54 AM
RWhisen's Avatar
Take a look at the links Tweety posted. These are much more useful than front or rear stands.
Old Oct 1, 2010 | 07:06 AM
I got spools on the swingarm for rapid use of a rear stand at the track...
But like you said, this makes it much easier to work on the bike, no stands to trip over, and you can like I said using a block of wood or a floorjack under the sump remove the forks and the swingarm without any other support...
Old Oct 1, 2010 | 07:13 AM
BTW the measurements I have in the PDF is pretty model specific as the VTR has no good connection points besides those motor bolts... I made it to be as close to the bike as possible, to keep the bending forces at a minimum... So if you have a lower, you might want to adjust the width at the top a bit...
But it works just fine for a lot of other bikes, just make the uprights lower and measure out a decent height for the holes and use some other studs for that particular bike...
The leaning upright is that way to make room for the sidestand... This way it clears the stand and you can keep it out for quick jobs, not forgetting it once going down... Or pop it in for longer work...
Old Oct 1, 2010 | 08:15 AM
RWhisen's Avatar
Thanks for the PDF Tweety! I couldn't believe I "missed" it then saw you edited that post.
Matt_Hawk
Dec 26, 2011 06:43 PM
DocPigskin17
Mar 27, 2008 06:52 AM
jim2000VTR
Jan 28, 2008 05:22 AM
sprhawk neil
Feb 28, 2006 04:22 PM
rray
Jan 18, 2005 07:38 AM
