Quick action throttle
Welcome!
that's a good one. Haven't heard of quick turn throttle for the suphwk. Did you search any stunter forums?
https://www.superhawkforum.com/forum...tle-kit-22314/
HRC throttle maybe
HRC throttle maybe
you can always make your own with some plastic pipe...
take some pvc pipe and cut a thin section, then cut a slit in it to make it a C so you can fit it in the cable guide and presto - short throw throttle tube - and all it took was a couple dollars at the hardware store... or less if you have some lieing around...
HRC Part 53141-MT7-000 is a quick turn throttle tube that fits right in, no mods required. The only caveat is it takes up most of the available cable adjustment. It's available from Partzilla, ETC. for about $25 USD.
Shawn Torpey
Oct 17, 2010 06:01 AM
