New To The Forum
Old Oct 3, 2009 | 02:59 PM
bjorn toulouse's Avatar
Destructive Tester
New To The Forum
Thursday I spotted a SuperHawk on the local CL for a pretty cheep price. After making arrangements to see it Friday a.m., I found the forum and started looking into why it wouldn't run for the guy. Based on his description of the symptoms and what info I found here, I figured that the reg/rect had gone belly up.
Yesterday I bought the bike and drug it home. Today I got into the wiring and sure enough, the reg/rect is hurtin', as is the harness connector. All else checks out OK (the battery is junk, but that's no big deal), so a new reg/rect and harness repair is on the agenda.
Based on scribblings on the back pages of the Owner's Manual, there is a DynoJet kit in the carbs, Gold Valves and stouter springs in the forks and possibly tapered roller bearings in the steering head. There are some funky stainless brake lines on the front, but the rear and the clutch are OEM rubber.
Having already tried to make a VFR comfortable for my Ol' Geezer body, I'm planning on putting a set of bar mounts on the upper triple clamp and a set of Superbike bend bars. This rig should keep me occupied through the oncoming winter, there's a bit of previous owners messin' with thaat needs to be straightened out.
Here's a pic of the bike after unloading it from my van.........it's a 50 footer!
Mmmmmm, toasty!
Rex
Old Oct 3, 2009 | 03:55 PM
stebbdt's Avatar
COBB Member
Welcome from another new member, keep us posted with lotsa pic's.
Old Oct 3, 2009 | 04:24 PM
Welcome.
I have stock bars, but adding a Sargent seat 1 1/2 years ago sure made my 62 year old butt happy.
Old Oct 3, 2009 | 05:03 PM
j shizzy wizzy's Avatar
mildly retarded
Welcome!!
Old Oct 3, 2009 | 06:38 PM
RickB's Avatar
Welcome to the site!
Old Oct 3, 2009 | 08:02 PM
Welcome aboard! Projects rule. Especially when they're superhawks
Old Oct 3, 2009 | 08:15 PM
Syclone's Avatar
Boosted
Welcome to the forum.
I spy an undertail and possibly upgraded front calipers? And stock CCTs :/ How many miles and what year?
Old Oct 3, 2009 | 08:57 PM
The connector under the seat on my bike just cratered like that. As is written on other parts of the forum. I soldered the wires across the connector and made sure the shrink wrap was as tight as possible. Stator was fine, fukt up little cheapie r/r was fine. Over engineered Japanese Motorcycle - adapted.
Old Oct 4, 2009 | 05:56 AM
Destructive Tester
It's a '98 with a bit over 28K miles. According to the records in the owner's manual, it has had fairly regular service intervals, and the previous owner(s) used moto-synthetic oil. I pulled the rear cam cover for a look-see at the innards, and everything looks very clean. I was hoping that there would be a K&N filter in the air box, but a semi-clean OEM filter was found instead.
I didn't think the calipers were the original. The OEM calipers were gold, from what I've seen. What is the reason for changing to CBR, or whatever, calipers? Are the piston sizes different? Are the bodies more rigid??
An undertail and a hugger have been fitted. It also has a Hyperpro steering damper, which is going to come off as soon as I round up a 30mm socket for the top steering stem nut. The rider pegs have been changed to pre-beveled aftermarket aluminum bits. Myself, I'd rather have the rubber covered OEM pegs.
Oh well, I knew this bike was gonna be a project. The first order of business is getting the electrical system squared away. Once the queertrons have been eradicated I can move on to comfort and cosmetic issues.
Here's a pic of the Hyperpro damper. It's for sale or trade if anyone is interested.
Rex
Old Oct 4, 2009 | 08:22 AM
MOONSTER's Avatar
Welcome to the forum. That's a big plus on converting to superbike bars. Just did mine & makes a world of difference. Good Luck!
Old Oct 4, 2009 | 08:27 AM
The pistons are considerably larger, if the M/C is the stock VTR, consider swapping it too a CBR one and you will get considerably more bite and feel, the stock one is a bit wimpy and matched to a CBR caliper you will get a looooong pull...
Old Oct 4, 2009 | 08:45 AM
drew_c14's Avatar
From the glimpse of the M/C I got in that one picture it looks like it has been changed. You might be doing alright depending what it is. If you can give close up's of the calipers and M/C or maybe some numbers off of them we might be able to tell you what you working with.
The stock front brakes on these bikes are pure garbage, upgrading them is a common mod.
Old Oct 4, 2009 | 10:23 AM
From the look I would guess those are F4i calipers (good choice) but not sure on the MC as a F4i MC would have an integrates Res.
Oh, and welcome!
Old Oct 5, 2009 | 06:02 AM
Destructive Tester
I think the front master cylinder is the stock bit. I put an F4i master cylinder on my Tiger 1050 to be rid of the standard "urine sample cup" Triumph fitted.
I find the sample cup style units are pretty hard to look at when they're hangin' out in the breeze on regular handle bars.
Rex
CBR master cylinder on Tiger.
Old Oct 5, 2009 | 07:02 AM
steve.g's Avatar
Welcome.....
Old Oct 6, 2009 | 10:07 PM
shayne's Avatar
Welcome aboard.
Planty of good mods you can do to the VTR.
Old Oct 7, 2009 | 03:23 AM
Billzilla15's Avatar
welcome to the forum, whereabout are you from i see north eastern ohio im from the chagrin falls area and was just curious.
Old Oct 7, 2009 | 06:22 AM
kmm996's Avatar
kmm996
Welcome.
rpolliard
Jan 15, 2013 02:05 PM
Colors
Jul 20, 2012 10:56 AM
kelpike
May 4, 2011 05:55 PM
Hawkrider
SuperhawkForum.com News
Jan 10, 2009 10:05 AM
Milkman III
Jun 29, 2005 02:11 PM
