My Superhawk not start
Old Dec 6, 2010 | 07:56 AM
mau's Avatar
mau
mau is on a distinguished road
Unhappy My Superhawk not start
hola! my name is Mau and I have a superhawk996 but I have a problem, my bike will not start, just "click" when I start the engine, this will be the relay next to the battery on the red wire? Thanks for your answers!
Old Dec 6, 2010 | 10:13 AM
RCVTR's Avatar
Pull the connector off the top of the starter relay. Make sure the terminals are not corroded.
Old Dec 6, 2010 | 10:30 AM
mau's Avatar
mau
Thank`s man!
Old Dec 6, 2010 | 11:46 AM
Old Yeller's Avatar
do you have a volt meter to check the battery? it should read 12.6 to 12.8 volts at rest if it's fully charged.
If it's not, you can either charge the battery or jump start it. Either way, check the voltage again while it is running to see if you are getting a good charge to your battery. it should read approximately 13.8 volts while running. even as high as 14.1 is ok.
Old Dec 6, 2010 | 11:54 AM
Wicky's Avatar
Also check the starter motor connector bolt and cable where it attaches under the rubber boot for corrosion. If water gets in through the seals it can damage the SM and/or if the cable gets knackered. keep it greased up!
http://fiche.ronayers.com/Index.cfm/.../STARTER_MOTOR
Old Dec 6, 2010 | 01:02 PM
And for the blatantly obvious... Check that the killswitch is in the correct position... It wouldn't be the first time someone forgot that...
Old Dec 6, 2010 | 01:15 PM
RCVTR's Avatar
I only do that at stoplights, in the middle of rush-hour traffic...
Old Dec 6, 2010 | 01:17 PM
To add to to Tweet's obvious... If your sidestand switch is faulty/broken it won't start unless you've got the clutch pulled in... or are in neutral
Old Dec 6, 2010 | 01:36 PM
I have once nearly ended up getting the bike on a trailer after a stop at a gas station... I was at my wits end, and about to call when I finally remembered to check the switch...
Talk about embarassed... But the bystanders got a big scare when the bike decided to burn off the excess fuel I had pumped into it trying the starter... The backfire and resulting flame scared the crap out of them... And me...
Old Dec 6, 2010 | 01:57 PM
You can DO that!!!!???? I wanna try!
I have run my starter till my battery died b/c I had forgotten that I had my fuel valve shutoff...
Old Dec 6, 2010 | 02:08 PM
mau's Avatar
mau
Yes, I checked the battery charge, is with good load, and when I turn one does, "click"
Old Dec 6, 2010 | 02:16 PM
mau's Avatar
mau
Check the battery positive line, check the proper funionamiento the relay, from there I go to the starter motor to see that the leads were correct, remove the starter motor and connect it directly to a battery and perfect twist
Old Dec 6, 2010 | 02:38 PM
If it's only going "click", the kill switch or side stand switch are not the problem.
Check all other items mentioned above plus, make sure the engine turns freely (not seized or hydrostatic lock). With the key OFF, and the bike in a high gear, not 1st or 2nd, try pushing the bike. If you can push it, the engine is turning freely.
Also, have someone try to crank it while you hold a voltmeter between ground and the + starter terminal. If you don't get voltage, the starter is NOT the problem. If you do get voltage (and the engine turned freely when you pushed the bike), you need a new starter, providing the electrical connection and starter mounting bolts are clean and tight.
Old Dec 6, 2010 | 02:42 PM
I was slow in completing my last post. After reading your last post, I would say try pushing your bike, like I said above, to see if the engine turns freely. The higher gear you use, the easier it will be to push. 6th is best.
Your starter is good if it turns freely and at high speed when removed from the engine.
Old Dec 6, 2010 | 05:14 PM
mau's Avatar
mau
Thanks, I'll try and make them comment that
Old Dec 7, 2010 | 03:27 PM
ascothawk's Avatar
ascothawk is on a distinguished road
My starter relay failed a couple years ago.I had 12.8 volts at the positive battery cable side(red ) and only .2 volts on the starter cable side when the starter button was pushed.The fuse was good.I bought a used one on ebay for 15.00.
Old Dec 7, 2010 | 11:28 PM
PUSHrod's Avatar
In the category of free, easy or cheap diagnosis: My money rides on a bad battery. Same symptom on my 'Hawk. It would show good voltage after a night on the battery tender but only click when attempting a start. The fault was a transient internal cell short. Pull it, charge it then load test it down at an auto parts store.
A Wal Mart battery, the 'mat technology' was the replacement and I've been happy since.
Old Dec 10, 2010 | 10:48 AM
rbrais's Avatar
Try flipping the kill switch for about 2 seconds while you are cruising down main street then fire it back up.
Old Dec 17, 2010 | 07:08 AM
mau's Avatar
mau
I tested to put in a high gear and pushing but does not turn the wheel, trailing only
Old Dec 17, 2010 | 07:37 AM
Stevebis1's Avatar
That's doesn't sound promising. I suppose it's possible you didn't have enough traction, you might want to pull the plugs and try pushing again.
You haven't told us what happened the last time the bike worked. Any odd sounds when you put it away? You have to confirm the engine will turn before we can go much further.
Old Jul 25, 2011 | 04:18 PM
mau's Avatar
mau
Nuevamente estoy visitando el foro, efectivamente el motor ya no funciono, los cojinetes de biela no funcionan, voy a cambiarlos por unos nuevos en medida "std" alguien me puede ayudar con el numero de parte.
Today my english it's not good, sorry
Old Jul 25, 2011 | 04:23 PM
mau's Avatar
mau
somebody we can help'me with part number of, bearing of "biela"
the image is color red,
thanks
Old Jul 25, 2011 | 09:40 PM
RIPI's Avatar
RIPI
RIPI is on a distinguished road
Keep it off for ten seconds when someone is tailgating and maybe the exhaust outlet will act as a big projectile!
Old Jul 25, 2011 | 11:58 PM
franz125's Avatar
franz125 is on a distinguished road
thanks
Conrod
Montana
Aug 7, 2010 07:12 PM
amhsraptor
Jul 12, 2010 06:55 PM
vtr98bob
Jul 14, 2009 08:55 AM
ghopki1
Jun 4, 2009 08:17 PM
jivtrky
May 17, 2007 12:49 AM
