My first VTR, well most of one
Old Jan 12, 2009 | 11:13 PM
  #121
kai ju's Avatar
front head is FINISHED. Exhaust ports are polished up to a nice shine. Now i need a valve spring compressor so i can re assemble it, can you guess how i took it apart without one?
Socket and a hammer.
Place a rag inside the combustion chamber with it facing down on the work bench.
Place the open side of the socket on the valve spring retainer and give it a quick rap.
The keepers dislodge because the valve doesn't move (remember the rag ?) but the retainer does.
Kai Ju
Old Jan 13, 2009 | 05:53 AM
  #122
Truckinduc's Avatar
I used a socket and a bar clamp.
My favorite way to do it is a modified c clamp, works better than 4 fancy valve spring compressors ive tried.
Old Jan 13, 2009 | 07:19 AM
  #123
kai ju's Avatar
That will also work to put it back together with.
My method is merely suitable for quick ( and dirty ) disassembly.
Kai Ju
Old Jan 14, 2009 | 03:47 PM
  #124
Truckinduc's Avatar
well the front head is done. Ill probably get to work on the rear head most of the day tomorrow. Should finish it up i hope. Got a new carbide burr and im dying to try it out.
Old Jan 14, 2009 | 03:57 PM
  #125
Truckinduc's Avatar
Kai Ju
Sounds like a potential valve bending experience
Old Jan 14, 2009 | 04:00 PM
  #126
Truckinduc's Avatar
Hey Kai Ju i forgot, you are using pusher fans right?
Im planning on using 2 radiators stacked, the one on top being smaller.
The coolant will go through the bottom rad first then be cooled further by the upper smaller one.
Im trying to decide if i should use pusher fan of puller, but my mind will probably be made up by my very limited space.
Old Jan 14, 2009 | 04:50 PM
  #127
kai ju's Avatar
To push or to pull..................
Puller fans are far more efficient than pushers.
If you have the space between the radiator and the wheel, go with a puller, but you may need two to get enough airflow for high speed/high ambient temperatures.
Using a stock VTX1800 radiator forced me to use first one, then two pushers.
Very early on in the life of the bike I actually had a puller directly opposite the pusher, with the radiator in between,which worked reasonably well.
Once I installed the VFR tank I had to raise the seat to match the rear of the tank to the front of the seat. That gave me the space to run two pushers under the seat and the bike has never even come close to running too hot.
Kai Ju
Old Jan 14, 2009 | 05:07 PM
  #128
Truckinduc's Avatar
Im aware that the pullers are far more efficient. Im considering making a shroud from the underside of the radiator that flows twards the rear where i can mount a bigger and more efficient fan. Ill make the shroud out of fiberglass and later carbon.
Im also wondering if I should make another shroud from the top side of the radiator to a high pressure area.
Old Jan 14, 2009 | 05:37 PM
  #129
Gregw's Avatar
I have just the thing.
Old Jan 14, 2009 | 06:31 PM
  #130
Truckinduc's Avatar
thats straight up 70's Formula one technology right there
Old Jan 15, 2009 | 07:34 AM
  #131
kai ju's Avatar
Just don't forget that it's there when you pull into your garage.............
Or when you get ready to get off the bike................
Kai Ju
Old Jan 15, 2009 | 07:38 AM
  #132
kai ju's Avatar
I had made a couple of shrouds that ended up just inside of my knees, which on a naked bike is a high pressure area.
Sealed everything off with tape,including the subframe around the radiator, but did not seem to make a difference.
The one thing I haven't tried is to vent the top of the tailsection since the area behind the rider is a low pressure area and should promote airflow.
Kai Ju
Old Jan 15, 2009 | 08:51 AM
  #133
hawxter996's Avatar
ole dirty bastard
you steal that from a fiero gt?
Old Jan 15, 2009 | 11:12 AM
  #134
Truckinduc's Avatar
Kai Ju
Ive already got that planned, it will look something like the exhaust on the Ducati D16rr
Old Jan 16, 2009 | 04:09 PM
  #135
Truckinduc's Avatar
well since no one commented on my carbon fiber monocoque body idea, IM GONNA DO IT.
Ive got the flu and bronchitis and feel like **** still.
Old Jan 18, 2009 | 09:16 AM
  #136
Truckinduc's Avatar
can anyone post up the wiring diagram here? Ive tried to download the one on this site 5 times now with no luck
Old Jan 18, 2009 | 09:27 AM
  #137
Here is just the wiring diagram from the service manual.
http://dl.getdropbox.com/u/219618/VT...3_VTR1000F.pdf
The whole manual is available for download off this site if you have the time to get it all..
Here: https://www.superhawkforum.com/forum...ad.php?t=11365
but it is 104 MB
Old Jan 18, 2009 | 09:33 AM
  #138
Truckinduc's Avatar
thank you but ive tried downloading it already, for some reason it wont work with my computer
Old Jan 18, 2009 | 09:34 AM
  #139
Did the wiring diagram I uploaded work for you?
Old Jan 18, 2009 | 09:56 AM
  #140
Truckinduc's Avatar
im trying to get adobie so i can open it
Old Jan 18, 2009 | 10:11 AM
  #141
Truckinduc's Avatar
it worked, but It seems as though its only half the diagram, Hmm
Old Jan 18, 2009 | 11:41 AM
  #142
cliby's Avatar
very nice work so far - and you work fast! I might have missed it in the first post but what do you do for work? - this looks like a full time job at the rate you have been working. Can't wait to see the finished product.
Old Jan 18, 2009 | 01:44 PM
  #143
Ok try again.. It will be the same link, so redownload it
I goofed on the pdf settings
Old Jan 18, 2009 | 02:30 PM
  #144
Truckinduc's Avatar
thank you lazn, it works great. Now i have to decide weather to make my own wiring harness or modify the stock one.
Im un employed at the moment Cilby. Ive been doing odd jobs in order to pay my medical bills. Ive still got an extremely fucked up knee, but i got to make money some how.
Right now in building a big deck about 60 foot up on the roof of a house.
Lifting 250 lb 2x10's 60 foot up is not exactly easy.
Old Jan 18, 2009 | 03:04 PM
  #145
Truckinduc's Avatar
oh an to top that off ive still got the flu and bronchitis, coughing up blood.
I ported and polished the rear head today, i still need to do the valves, but im tired of the head,
SO IM OFF TO ARMOR PLATE THE CASES
Old Jan 18, 2009 | 03:50 PM
  #146
finepooch's Avatar
i just found this thread. WOW!!! truckinduc, you've definitely got skills!!! 19 years old! awesome!!! you should be employed!!!
i think you said you got the bike cheap - hopefully free, or maybe you bought the po lunch at the drive through?
hopefully you turn nothing into something!
Old Jan 18, 2009 | 08:26 PM
  #147
Truckinduc's Avatar
here is a rough idea on the bodywork. Its all gonna be carbon fiber and painted with Cadillac pearlescent white paint.
Old Jan 19, 2009 | 07:55 AM
  #148
The exhaust needs to line up with the bodywork. If you're really gonna angle the subframe and seat like that I suggest you find a really good and comfortable athletic cup.
Old Jan 19, 2009 | 08:52 AM
  #149
finepooch's Avatar
yes, lines, line in paralel
perhaps exhaust under the bike, paralel to the ground?
Old Jan 19, 2009 | 09:07 AM
  #150
SlowHAWK's Avatar
Being that you 19.... you probably won't have too many complaints, but I angled my seat slightly higher and steeper than stock on my GSXR tail I'm in the process of doing, and it's gonna make my back and wrists hurt a bit more than the stock locations...
While I liek the design... with the seat in the placement your showing, your gonna be WAY up there height wise, and maybe a bit akwardly forward... I'd suggest mocking it up with some foam/wood first, as I think you'll be suprised of the feel.
Keep the images coming... looks like a good design though.
J.
