My first VTR, well most of one
Old Jan 20, 2009 | 04:29 PM
  #181
1zeppfan's Avatar
1zeppfan is on a distinguished road
If i was half as motivated at 19 as you are i would be sitting on a beach somewhere. Nice work man looks like you thought this threw pretty well.
Its like crack I'm waiting for more.
Old Jan 20, 2009 | 06:36 PM
  #182
OK PEOPLE THIS IS WHERE I NEED YOUR HELP.
I need the height off the ground of the swingarm pivot point while the bike is standing up.
Well on the "high side" on the kickstand it is: 16.5" and on the "low side" it is: 14"
And if I try to hold it up to what seems like straight it is 15"
This is with no weight on the bike, hope it is a help.
Old Jan 20, 2009 | 06:42 PM
  #183
Truckinduc's Avatar
thanks man, it will definitely help. Im just trying to get it in the ballpark.
Old Jan 20, 2009 | 06:46 PM
  #184
Truckinduc's Avatar
I think Ive decided I am going to powder coat the frame, swingarm, and some engine pieces.
Ill sandblast the stuff myself, so I think I can get it all done for about 100 bucks, well at least I hope so.
Im thinking wrinkle black for the frame and swinger, and a dark gunmetal color for the engine bits.
What do you guys think?
Old Jan 20, 2009 | 06:52 PM
  #185
FL02SupaHawk996's Avatar
Fastest Color
I think it'll look sweet! keep the pics coming please
RC
  #186
That could look good..
Old Jan 20, 2009 | 06:53 PM
  #187
SlowHAWK's Avatar
Frame and swinger in black definitely.... not sure about wrinkle though. I'm probably gonna go with a semi-gloss (60% ish) for my VFR swinger... and maybe the frame if I'm not too lazy and unbolt everything.
J.
Old Jan 20, 2009 | 07:41 PM
  #188
Truckinduc's Avatar
600RR swing wont fit... not even with your skills... Its one solid pipe all the way at the pivot bolt... (ie no overlapping between frame and swing as stock) 1000RR is the same...
However CBR 929/954 works with a lot of work... needs a new header and moving the suspension... plus a lot of fiddling since it's a 25mm pivot bolt...
RC51 swingarms fit with a little less work... an SP2 one is almost bolt on... SP1 has a larger pivot...
Also apparently for single side an Augusta MV4 swing shouuld fit...atleast it fits a VFR...
hey tweety look at this, 600 rr swinger
Old Jan 20, 2009 | 09:14 PM
  #189
Scumbag's Avatar
Scumbag is an unknown quantity at this point
Lookin killer man...good to see another hawk that is stripped
Oh and it looks like tweety just got pwned...
Old Jan 21, 2009 | 02:22 AM
  #190
It happens every now and then...
What year is that? It's the first I have seen like that... All of them I have seen has had a detachable pro-link mount (4 bolts) and a completely different pivot...
That however should work nicely... I'm bad at working in inches... so what are those dimensions in mm?
Another thing thoo... It look like the shock sits about where the rear header is on a VTR... Not much room there...
Old Jan 21, 2009 | 02:30 AM
  #191
Oh BTW I don't know how you define pwned... I still say it's going to take a lot of work... as in A LOT... and a linkage for a pro-link is a lot more complicated than a classic one...
Old Jan 21, 2009 | 06:05 AM
  #192
Truckinduc's Avatar
Actually this is the first one ive seen thats not solid. The ones with the detachible pro link mount are the earlier versions, Pre 2005 I believe.
Im not sure of the year of the pictured one but ill find out.
Old Jan 21, 2009 | 08:09 AM
  #193
hawxter996's Avatar
ole dirty bastard
looks like a 2005
Old Jan 21, 2009 | 12:56 PM
  #194
finepooch's Avatar
i'm still watching
Old Jan 21, 2009 | 01:05 PM
  #195
SlowHAWK's Avatar
Hey Truckinduc...
Check this thread out about swingarm dimensions....
https://www.superhawkforum.com/forum...m+measurements
And then kindly add the CBR stuff if possible!!! Thanks...
J.
Old Jan 21, 2009 | 01:54 PM
  #196
Truckinduc's Avatar
I would, but im not positive of the measurements.
Rearsets anyone?
Old Jan 21, 2009 | 03:26 PM
  #197
Scumbag's Avatar
No harm...hahha...You have the knowledge...
Old Jan 21, 2009 | 03:28 PM
  #198
Scumbag's Avatar
I like rear sets....so what kind of R and D needs to be done? hahah
Old Jan 21, 2009 | 03:37 PM
  #199
Truckinduc's Avatar
Old Jan 21, 2009 | 04:45 PM
  #200
Truckinduc's Avatar
The welds look alot better in person, but my cell phone sucks
Old Jan 21, 2009 | 07:36 PM
  #201
Truckinduc's Avatar
Does anyone have a diagram of the cooling system for the bike? Can I see it please?
Old Jan 21, 2009 | 08:12 PM
  #202
Gregw's Avatar
Check chapter 6 of the shop manual. There is a PDF version in the Knowledge Base under a stickie called "Service Manual" https://www.superhawkforum.com/forum...ad.php?t=11365
Old Jan 21, 2009 | 08:40 PM
  #203
Truckinduc's Avatar
I have tried and tried and cant download the manual. Damn computer. Thanks anyway.
Old Jan 21, 2009 | 09:51 PM
  #204
I uploaded another copy of it, try and see if you can get it from here:
http://dl.getdropbox.com/u/219618/VT...3_VTR1000F.pdf
Old Jan 22, 2009 | 04:58 PM
  #205
Truckinduc's Avatar
WOO HOO I finally successfully downloaded the service manual.
I ordered new head gaskets and side cover gaskets today.
I moved my oil cooler but I dont have the right size metric tap to tap 2 holes in my block so it will have to wait.
I finalized my idea for my airbox. Its gonna be low volume side mounted k&n filter with ram air scoop coming out the right side between the frame and front head.
I need as much room as I can under the tank, This is all thats going in there.
Both Dynacoils
Ignitor box
reg/rect
other ignition box
fuse block
AND THE BATTERY
all thats going under the tank and cant stick up more than an inch above the framerails.
Its going to be tough to get it all in there neatly.
Old Jan 22, 2009 | 05:50 PM
  #206
Truckinduc's Avatar
SO I just realized my bike is missing the entire thermostat housing. Im re doing my entire cooling system anyway so im wondering what adverse effects ill have by not running a thermostat.
I know it will take longer for the bike to fully warm up since the coolant is flowing.
Ill be running 1 radiator under the tail of the bike instead of the stock dual side mount. The rad will have 2 86 cfm fans to handle the cooling duties. The fans will be hooked up to a 3 position switch. The 3 positions are OFF, automatic(electric thermostat controlled), and manual ON.
SO, what do you think?
Old Jan 22, 2009 | 08:31 PM
  #207
lynchie's Avatar
AZ RIDER
pops rocks
Your dad Rocks, great work, too bad you dont live in AZ..tooling in the garage and re-inventing the wheel is lots of fun with the right tools, and sometimes without..
Old Jan 23, 2009 | 06:41 PM
  #208
I'm hosting the manual on my site now. Link is updated on the sticky.
Old Jan 23, 2009 | 09:05 PM
  #209
Truckinduc's Avatar
Little update.
The honda store wants 25 bucks each for the rubber boots that connect the carbs to the heads. I didnt even price the 4 clamps i needed also.
I went to autozone and got a radiator hose and the 4 clamps for 18 bucks total. Would have been cheaper but 2.25 is an odd size.
I also went to Batteries plus and talked batteries to the guys alot. Ive decided on a z10s battery thats absorbed glass matt, pretty small, and gives me 185 cca.
I mounted the carbs when I got home. Also figured out where all the electronics will be going. Gonna mount the coils tomorrow hopefully.
I mounted the remote reservoir for the shock. Had to modify and TIG an exhaust can hanger for a Ducati 998. I love the position of the reservoir now that I spun the shock 180.
anyone know if 5 OHM dyancoils will work with the VTR ignition system? They are off my monster.
Old Jan 23, 2009 | 09:28 PM
  #210
Truckinduc's Avatar
its all in the details
