Are long wheelies a danger?
Old Oct 16, 2013 | 07:42 PM
  #61
msethhunter's Avatar
If you had more experience, you would have seen more
I've pulled down many engines, 4 stroke, 2 stroke, auto, truck and motorcycle that had damaged wrist pins / wrist pin bores in the piston due to lack of lube, over heat, oil debris, failed circlips or Teflon buttons.
It's hardly uncommon ... though not common in a serviceable motor that is just worn out.
But hey, you don't trust what I say... so carry on...your just way to educated and experienced to listen to me.
I said nothing about being damaged and worn out. I said failure. Seen lots of "non-serviceable" piston and rods because of lack of oil on the small end. And it is usually due to neglect. Like always running low on oil, lack of oil changes. I used to do it for a living, but have moved on to brighter pastures.
Edit to add: Likewise, feel free to ignore my posts. You just had to get that other reply in didn't you?
Wolverine
Jun 23, 2011 08:51 PM
havoc7685
Sep 16, 2010 01:13 PM
Laynout
Aug 29, 2008 07:07 AM
vtrlvr
Jun 16, 2007 10:44 AM
FordsnRebels
Nov 8, 2006 11:40 PM
