knock knock....
Old Jun 22, 2006 | 11:51 AM
Lilbitz909's Avatar
Lilbitz909
knock knock....
I posted a thread probably about a month ago about a real loud knocking nosie coming from the engine... I thought maybe the timing chain or something in that area broke or got loose.. But comes to find out from many peoples opinions from listning to it they all said that it was my valves knocking... Which makes since cuz the bike will run but there is just a real loud knock "clicking" noise... and if were the timing chain the bike would'nt run.. So has anyone messed with the valves before? Or even heard of this problem happening?? Is it possible that something in the whole valve set up broke, or just got real loose. Any advise or info would be very helpful.. thanks
Old Jun 23, 2006 | 06:43 AM
Lilbitz909's Avatar
Lilbitz909
So no one has ever messed with the valves???
Old Jun 23, 2006 | 07:00 AM
denmah's Avatar
denmah
you most likely need a valve adjustment.
Old Jun 29, 2006 | 12:23 PM
smonska's Avatar
smonska
Check the CCTs!!! These are the most common part of failures on superhawks and make a loud clicking noise almost like valve or rod bearing. I'm really surprised no one on this board mentioned this earlier. Search the board for cam chain tensioners or CCTs and see what I mean. Good luck! I hope its nothing $$$. :-)
CruxGNZ
Apr 25, 2015 07:53 PM
Sablotny
Oct 19, 2008 03:34 PM
follmer_af
Aug 5, 2008 11:21 PM
CentralCoaster
Jul 5, 2008 04:54 PM
reelectreagan
May 25, 2005 01:51 PM
