gas mileage
Old Apr 27, 2008 | 03:43 PM
rooskie's Avatar
rooskie is on a distinguished road
Question gas mileage
how large is the gas tank on a 2000 superhawk 996. the book tells me its 4.23 gallons but for some reason i only get 80miles to a tank of gas. is that the right amount or what should be checking for. is the tank smaller than what the book says it is? i need to find out how to troubleshoot this problem. please any suggestions,comments,answers would be welcome. thx
Old Apr 27, 2008 | 03:45 PM
drew_c14's Avatar
80 sounds about right, you're probably only putting in 2.5-3.0 gallons each fill up right?
Old Apr 27, 2008 | 05:09 PM
Yeah, what's your MILEAGE?
Old Apr 28, 2008 | 04:41 AM
nnjhawk02's Avatar
After Stage 1 Jet Kit - the mileage sunk like a lead weight -
I recently tested my mileage - not by choice
And fuel light came on @ 107 - made to 133 - didn't run out - I believe when I filled up I took 3.9 & change
Wasn't gunning the gas for the last 40 miles of ride.
Thus - I typically get about 32 mpg - about the same as my Civic
Old Apr 28, 2008 | 05:03 AM
synaptik's Avatar
synaptik is on a distinguished road
i get about the same MPG as my civic si on my 2000 superhawk, i have only ever put more than 3 gallons in at a time (when i pulled the tank), i stop the moment i see that RLOD if i can,
i did get the RLOD this weekend at 80 miles on a full tank ... i was pretty pissed
Old Apr 28, 2008 | 05:24 PM
rooskie's Avatar
yeah between 2.5 and 3 gallons. am i supposed to run out but if i run out its only at 80 miles hell i can't ride anywhere lol. the 1st owner put alot of miles on the bike. i can't believe he only rode 80miles each time
Old Apr 28, 2008 | 05:29 PM
rooskie's Avatar
so u guys r telling me that 80 miles for a tank of gas is the norm?
Old Apr 28, 2008 | 05:34 PM
happytrack44's Avatar
WERA #44
Last 2 full day rides I refilled with my group at about 125 miles, didn't have the fuel gauge hooked up, but I had some gas left at 125. I have a set of MIG pipes, jetted right to match, K&N air filter, sprockets are down one in front and up 2 in back. I wasn't gentle with it sometimes. Some of the best riding ever.
Old Apr 28, 2008 | 06:04 PM
Randman's Avatar
Moderate-whore
I get 55 mpg....LOL...and lovin it!!
Old Apr 28, 2008 | 07:11 PM
rooskie's Avatar
so what should i do bout my problem? i have stock exhaust on it.
Old Apr 28, 2008 | 07:14 PM
rooskie, you need to tell us the actual mileage that you're getting, not the miles per tank. It's quite possible that your fuel gauge/light is not working properly.
Old Apr 28, 2008 | 07:16 PM
Blue Ridge Boy's Avatar
Get your bike serviced...or do it yourself. Make sure parts are clean and running smoothly. And take it a little easier on the revs. I get around 80 miles to a tank if I'm racing through the hills in high rpms. Try not to rev it up so much and you will see a huge difference in your fuel mileage.
Old Apr 28, 2008 | 07:17 PM
Yeah...rooskie...are you sure when you're filling up that you are truly empty?
Old Apr 28, 2008 | 07:21 PM
superbling's Avatar
Running very hard with performance mods: 25-30mpg
Running hard: 30-35mpg
Easy: 35-45 mpg
Very easy: 45-50mpg
3.5 ish gallon tank before RLOD
Do the math
Old Apr 28, 2008 | 07:26 PM
RK1's Avatar
RK1
rooskie;
Can't tell from your posts if you have crummy fuel mileage or a crummy low fuel warning light.
Start this way;
Fill the fuel tank and zero the tripmeter. Ride for a hundred miles or until the fuel light comes on. Fill the fuel tank to the same level as you did last time. Divide the number of miles traveled by the amount of fuel burned. That's your mpg. All we know so far is that the light comes on at 80 miles. You need to tell us what your mileage is.
Old Apr 29, 2008 | 03:23 PM
I tend to fill at ~90 miles as that is the distance from my house to Prescott up 89a and that is my favorite ride.. But the RLOD (red light) usually takes between 95 and 120 miles to come on depending on how hard I ride it. I always reset the trip meter every fill up as I trust it more than that angry red LED.
Old Apr 30, 2008 | 08:17 AM
darylward's Avatar
darylward is on a distinguished road
Normal riding i am getting about 38/42. Only mods are jet kit and Exhaust.
Old Apr 30, 2008 | 09:09 AM
jbaxx's Avatar
Honducati
Easy: 35-45 mpg
Very easy: 45-50mpg
Do the math
+1
Old May 4, 2008 | 11:04 PM
BlackHawk04's Avatar
rubber side down
BlackHawk04 is on a distinguished road
This is helpful info about the gas mileage. I have wondered if my gauge is off...... I ran about 85 miles on last tank and my gauge said empty.... I filled and it was only 2.6 gal. That puts me at around 34 mpg, which is good since I carry my 85 lb. daughter to school everyday.
Any fixes on the gauge? It seems like that might be the issue on this thread too, I know there is more gas in there but never want to risk it, especially with a passenger. Thanks gangsters!
Old May 5, 2008 | 03:29 AM
FYI... If you don't like RLOD only there is a "fix"...
If you care to spend the money for the float arm from a never model VTR I can easily make a 6 LED fuel gauge to hook up to it... You get a 5 LED readout of the fuel level and a 6'th LED that comes on when completely empty, like the RLOD... this you can easily locate in the place of the RLOD (or in the place of the bulb on a different gauge, like mine from a CBR...)
I already did the designs since a friend on the Swedish VTR forum asked me about it... The circuit is small enough to go by normal mail to the US as long as you hook up the LED's and such yourself, so shipping it shouldn't be a problem...
nhowner
Sep 4, 2006 08:09 AM
bluesman
Jul 8, 2006 07:56 AM
motherbelgium
Aug 18, 2005 12:44 PM
divingindaytona
Jul 20, 2005 09:20 PM
mikstr
Jun 14, 2005 07:00 AM
