Extended Mirrors from eBay
Old Nov 4, 2010 | 07:29 AM
nekkid's Avatar
Does anyone have any experience with these?
I bought a set from slapi01 recently and while I can mount them on the bike, there is not enough adjustment range at the ball joint to allow the mirrors to function properly. They offer a stunning view of myself on the bike, but not the road behind or beside me.
slapi01 sold the mirrors to me without trying them on first and was unaware of the fitment problem. They sold/sell on ebay for about $50 and look to be Chinese made.
You may laugh at my predicament only if you offer constructive advice as well.
Old Nov 4, 2010 | 04:59 PM
Pictures would help but you can help yourself if you visit the knowledge base. I have the R6 mirrors that are talked about there. There are certain years that fit - not all.
Old Nov 4, 2010 | 06:38 PM
nath981's Avatar
i bought a pair of R1 mirrors for $29.00 delivered, loosened them at the pivot, adjusted them out, and put a self tapping screw to hold it in that position. This is actually the second set over the past couple years. i broke one in the garage, so got another set. I like them cause there's no weight to them, visibility is great, and they're expendable.
i don't know if yours are for an R1, they are a longer.
Old Nov 4, 2010 | 08:23 PM
nekkid's Avatar
Thanks guys. I did do a search in the knowledge base and the closest thing was a 2005 thread that mentioned generic mirrors on eBay.
slapi01 assures me that the mirrors he sold me were S'Hawk specific according to the auction listing. I'm not sure if the auction said they are for R1, R6 as well. He had posted a picture of them in his "for sale" thread about a month ago.
Old Nov 5, 2010 | 04:04 AM
nath981's Avatar
29 dollars:weigh nothing, cost nothing and work much better than OEM, which isn't saying much. haha. The only negative is that if you accidentally or intentionally fold them in w/o removing the set screw, you might be ordering a new set.
Old Nov 5, 2010 | 12:32 PM
nt650's Avatar
nt650 is on a distinguished road
Nath,
Did you have to modify them and add the self tapping screw so you could pivot them farther out?
Old Nov 5, 2010 | 12:50 PM
nath981's Avatar
Originally Posted by nt650
Nath,
they have little knuckles that keep them at the optimum position for the bike they were designed for, in this case the RI/R6. When you bump it or pull it back, it compresses a spring and this allows it to pass over the knuckle. I just pulled it to the position I wanted and drilled it. I guess you could make an angled wedge to fit under the base, but that's not the route I chose. I'm sure there's a better way to alter the knuckle so that it works as intended, but I didn't figure it out yet.
Old Nov 5, 2010 | 02:34 PM
slapi01's Avatar
slapi01 is on a distinguished road
here is the pic of them if it helps out nekkid..
this whole transaction leaves a bad taste in my mouth as i sold what i though to be no problem bolt ons to IDK.... like nekkid said i ended up putting bar ends on mine, so any help to get these mounted up looking purdy for him would br great... nekkid i will have the store narrowed down this weekend.. i'll pm you regardless of what you find out here
Old Nov 5, 2010 | 05:40 PM
Acecool's Avatar
Acecool is on a distinguished road
The rubber cover for the ball joint should be VERY hard to move. Get them on your bike and try using the leverage to move them!!!
Like your stock ones, you can SWIVEL the mirror itself, and you can ROTATE the bar either towards you or away from you to a certain distance.
If the boot on the bottom is not hard plastic (should be a stiff rubber boot), try to rotate them!
Old Nov 6, 2010 | 06:12 AM
You can unbolt the stems that attach the OE mirror "clevises" that mount to the fairing under the rubber boots, and grind off one side of the "rivets" that retain the stems to the mounts on the R1/R6/FZ1 mirror (and others). Then bolt the R1/R6/FZ1 mirror/stem with spring (wave) washers, flat washers of the correct OD & ID to the VTR mounts. Now you have easy adjustment and OE mirror orientation. I have custom machined, anodized extenders in between R1 mirrors and the OE mounts for a great rear view with 3 angles of adjustment.
Old Nov 6, 2010 | 07:34 AM
nath981's Avatar
now that's a possibility i never thought of. Might work!
tauntis
Jan 17, 2011 08:30 PM
lhoward1134
Mar 7, 2009 09:35 PM
jkrswld
Feb 3, 2009 06:22 AM
VTRsurfer
Aug 22, 2008 09:19 AM
pickle.of.doom
Feb 2, 2005 03:42 PM
