Breather or not
Old Feb 8, 2010 | 04:51 PM
996serrano's Avatar
996serrano is on a distinguished road
Breather or not
I have a 98 SH with 34,000 just bought it about a month ago, I have read losts of posts in here and even came across someone saying not to plug the crankcase. Well when I got the bike It had two bolts one on the rear cylinder and one on front cylinder. I have since replaced the bolts with crankcase breathers directly connected to valve cover. its a breather from auto parts store. My question is should I leave it with breather or put bolts back in?
Old Feb 8, 2010 | 06:19 PM
steve.g's Avatar
Not exactly sure what bolts/breathers you are talking about.There are breathers in the valve covers that are part of the PAIR system.This is for emissions. Some people just disable them,some remove the system completely.If you look for the sticky "Pair removal" in the knowledge base should tell you all you need to know. I have disabled mine to help stop the "popping" on overun in my aftermarket pipes.There may be a slight performance increase with disabling them,but I can't feel the difference.
Old Feb 8, 2010 | 06:40 PM
996serrano's Avatar
Breather or not
My bad this bike has had the pair system removed. I am simply talking about the connection to the valve cover that the pair used to connect to. It was plugged with one bolt on each cylinder. I added a crankcase breather and removed the bolt on the rear and the front cylinder. Is having a crankcase breather ok or should I leave the bolts in so the crankcase doesn't breath?
Old Feb 8, 2010 | 06:49 PM
996serrano's Avatar
Breather or not
This is what i mean.
autoteach's Avatar
The pair system can be plugged, but the breather system should not be. If the portion that is plugged of which you speak is connected to the aluminum colored piece that is bolted to the valve covers, play through.
autoteach's Avatar
By play through, leave it plugged.
Old Feb 8, 2010 | 07:11 PM
scatterbrained's Avatar
Squid Poacher
scatterbrained is on a distinguished road
+1
the pair system pushed outside air into the exhaust so plugging it won't hurt anything. Plugging the crankcase on the other hand. . . ..
Old Feb 8, 2010 | 07:17 PM
996serrano's Avatar
Breather or not
Originally Posted by scatterbrained
+1
So what i did is correct then right? The pic is my front cylinder and I put a breather on the valve there.
Old Feb 8, 2010 | 07:23 PM
killer5280's Avatar
No. That is what remains of the pair system. You can plug that with no worries. It doesn't need to breathe. It is not part of the crankcase ventilation, which are the larger hoses that go from the crankcase into the airbox.
Old Feb 8, 2010 | 07:31 PM
gboezio's Avatar
The crankcase vents are bigger than the pair hoses, what you put breathers onto are the PAIR reed valve covers, you should plug these and save the breathers for another use.
Plugging breathers will result in gaskets damage, poor mileage, on a V-twin, both cylinders are going down close to each other, the air need to rush out and back in. On an I-4 two up while 2 down, the breather is mostly to get the blow by and oil vapors out.
Old Feb 8, 2010 | 07:35 PM
996serrano's Avatar
Breather or not
Cool Killer thanks. When I got the bike I was like what the heck the crankcase is not breathing. So that is part of the pair system. Cool. I went outside and I see that there are larger hoses going to the underside of air box.
Old Feb 8, 2010 | 08:32 PM
autoteach's Avatar
Just had a stunning idea. On some high performance vehicles they run vacuum pumps on the crankcase. You could run a hose from the breathers to the pair system and build more HP with some low tension rings. Done and done.
E.Marquez
Nov 7, 2013 08:38 PM
chemomche
Oct 24, 2012 02:19 AM
spitfirerecords21
May 16, 2012 04:28 AM
clarkwebb
Jul 7, 2008 09:27 PM
ttenpas
Apr 28, 2005 08:09 PM
