bike has a whistle
bike has a whistle
adjusted the cct's last night, evreything is fine, no rattle or anything. but i went for a ride today, and im not sure if this is related or not, but under 4000 rpm i c an hear it whistling, like it has a supercharger on it. i can hear it while under load and decelerating, and also when i rev it. should i be concerned? i checked battery voltage and its at 13.56v. plugged in the battery tender and it went to charge mode for about 10 seconds and then showed it was fully charged. it also has a weird whine while cranking over to start. i just wanna make sure im not about to loose yet another rr.
That sounds like basic SuperHawk engine noise to me. Mine's had a high pitched "whine" since it was new. It was more noticeable with stock exhaust though, or when I run it now with the street baffles in.
I've heard some describe it as a sewing machine sound. But your description of it being like a supercharger sound is pretty accurate.
mines always had a bit of a whine but it was more noticeable today than ever before. last time it started to make a sound the rr crapped out. guess its a good thing i have a towing service. lol. lets hope it lasts i dont wanna replace it a third time
Since the topic is on Werid noises, My 2001 has made a whining since i've owned her, Kind of similar to the cam gear drive in the RC-51 engine... Have to agree with VTRsurfer- Was more noticable with the stock exhaust...
I have been putting another S-hawk(98') back together... and started it up... Have any of the group ever heard S-hawk which is all stock (stock filter, airbox, exhaust) make a "Howling" sound at idle to 6500 rpms. ? ?
hmm, interesting. i tightened the cct's as described, hand tight+1/4 turn. maybe ill back them off 1/4 turn and see what happens. the sound only happened since i last messed with it, lol.
speaking of sounds, ever since i bought the bike ive had a light rattle in third and 6th. this year the 6th gear rattle has gotten alot louder. annoying even to the point where i ride around in 5th gear. its loud. no idea what causes it. its been here all year. only thing we changed was the clutch and added a +4 timing advance to it. other than that it runs great. any ideas what would cause it to rattle?
Uchi,
Make sure your quieting gear is properly installed. This is a spring loaded gear on top of a gear which is located under the ignition timing plate.
[edit] Inserted a pic for clarification
ill have to get the air box off again this week and re adjust them one more time with the motor running. ive heard alot of people saying finger tight +1/4 when cold and off is fine. ill try it running and see if it makes a difference.
thanks for the help and the link
how I did the cct adjust was to tighten it with a small socket wrench so that i could tell the chain was tight, then back it off a couple turns, and then go back and finger tighten. This way you know where the end is, and you know that the threads are clean and free enough for finger tightening. I learned to do it this way when i adjusted the valves and when i could see/feel the chain tension and practiced it for when everything was covered up. Works well.
good point, could be some crap on the threads making it feel like its at the end right. ill play with it some more this week see what i come up with
my pair system has been ditched for a while now, but while im in there ill make sure something hasnt come loose from it. maybe re seal the air box just to be safe
If you do and don't want to tie up your bike for a while, buy a mic and sand your own shims. In this way you can get it done in one day and save yourself a bunch of running and waiting and money. Don't by the Hot Cams kit unless you do mind slop in some and tight in others. Sanding them takes little time and allows you to set your valves exactly where you want them.
https://www.superhawkforum.com/forum...oo-long-24459/
im guessing the carbs need to come off and then the valve covers follow, how hard are they to set? ive never done them but im gonna need to, i really do flog this thing in the worst way some times. im just waiting for it to explode, lol
Where can I get a whistle for my bike?
Just kidding. But I do believe our bikes can take more flogging than most, with our low compression ratio. But I hear you about the valve adjustment. I love doing valve adjustment on cars, but on a bike with shims under the lifters it's not fun. I've been putting mine off, but plan to check it in the next couple thousand miles.
One big advantage with shims is that they hold adjustment better than any other system. After all, we could be riding and working on desmo Ducs with their weird system.
easy to set if you are willing to sand the shims down to size rather than ordering the ones you think you need. I was able to get mine fairly precise and went +1 on intakes and exhaust because they tighten up, and so they should stay in spec longer. Look in the manual, but i don't remember removing the carbs.
I remember taking off the oil cooler and radiators for ease of access for the front, and for the rear, had the seat off and the tank lifted on the rear if my recollection is correct.
Shims under buckets valve adjustment on the old Jaguar XJS V12 was like 11.2 hours flat rate. Shops would quote $1000 or so for that job 20 years ago, but most didn't even want to touch it.
I've only done shims over buckets, on cars, which is much easier.
At least our bikes have big jugs
which makes it easier. You don't need to have tiny hands.
And I like nath's tip about stuffing a rag in front of the sprockets. You don't want to drop anything down there.
which makes it easier. You don't need to have tiny hands.And I like nath's tip about stuffing a rag in front of the sprockets. You don't want to drop anything down there.
JamieDaugherty
Dec 8, 2007 05:59 AM
futurehawk
Apr 14, 2007 11:08 PM
luiggispeed
Aug 17, 2005 01:57 PM
