adjusting the suspension
Old Jul 18, 2014 | 01:21 PM
bgarrett5's Avatar
bgarrett5 is on a distinguished road
I want to ride with my fiance on the motorcycle but in order to do that we have to adjust the rear suspension. I have looked online on how to adjust the suspension but I can not find anything. So how do we adjust the rear suspension that way I can ride on the back?
Old Jul 18, 2014 | 01:45 PM
Wicky's Avatar
Pg 59 - In the downloadable & searchable Honda VTR1000F Service manual PDF >
REAR SUSPENSION ADJUSTMENT - SPRING PRELOAD
The spring preload adjuster has 7 positions.
To change the spring preload, turn the adjuster
with the pin spanner.
Position 2 is the standard position.
Position 1 is for soft spring preload.
Positions 3 to 7 are for hard spring preload.
The rear suspension is pretty hard as standard (so you might not need to adjust much if at all) and the front is overly soft.
Old Jul 18, 2014 | 04:40 PM
Here is a pic that shows what you need to do. You need the spanner wrench from the tool kit. Higher up the ramp (larger #), the more spring preload (stiffer).
Old Jul 19, 2014 | 03:12 PM
BTW you need the tool which comes in the stock tool kit. It has a handle that goes on it. Give it a good wd40 spray to help you along.
Like this one if you dont mind dirty Honda Motorcycle Wrench 14 & 17 mm & Shock Spanner by RK Used
johnclopp85
Jun 22, 2009 12:12 AM
Gorwin64
Jun 17, 2009 04:26 AM
blacksheep
Aug 5, 2007 11:16 AM
EngineNoO9
Aug 24, 2006 11:45 PM
nellyshawk
Jun 18, 2006 04:00 PM
